First post, by murrayman
I'm curious about something. My Compaq Presario 5170 has an onboard ATI Rage LT Pro that has an empty memory expansion slot. The manual calls for in-house p/n 327591-001, which is this. But some ATI cards of the same vintage have their own memory expansion slots that appear to be the same form-factor, such as this.
Would it be possible to use the same memory expansion module used on a Rage card on the motherboard of my Compaq? Haven't found anyone else online exploring this particular thing yet. The Compaq manual does list both 2MB and 4MB expansion modules as compatible here.
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
Reply 1 of 1, by Anonymous Coward
Normally you should match the part number of the module to the one printed on the card. I think there are a few cases where you can mix and match, but ATi in general had a pretty bad habit of re-using connectors on upgrades that had completely different pinouts. At least, this is my experience with their Mach64GX upgrades.
