NetHack 3.6.7
First post, by akula65
Source: https://www.nethack.org/common/index.html
The NetHack DevTeam is announcing the release of NetHack 3.6.7 on February 16, 2023 […]
NetHack 3.6.7 is the official release of NetHack that follows NetHack 3.6.6.
This release primarily corrects a security issue present in NetHack versions 3.6.2, 3.6.3, 3.6.4, 3.6.5, and 3.6.6. For details about the security issues please see https://www.nethack.org/security. You are encouraged to update to NetHack 3.6.7 as soon as possible.
Here's a brief synopsis of the handful of bug fixes included in NetHack 3.6.7:
invalid status highlight color could be maliciously used to corrupt memory
formatting corpse names used internal buffers differently from formatting other objects and could potentially clobber memory
during engraving, spaces were counted instead of non-space (cherry-pick of 4e0a1e04 from NetHack-3.7)
avoid potential buffer overflow in append_str()
resolve missing dependency in NetHack.sln
code in include/tradstdc.h was trying to suppress warn_unused result by defining warn_unused_result to an empty string and that began causing a build error within a system-supplied header file cdefs.h when using Ubuntu Impish 21.10; disable that for any Linux and macOS gcc unless GCC_URWARN is defined to force it back into effect
update_inventory() after leash goes slack
player assigned name for monsters, specific objects, or object types could be longer than what was intented to be allowed; for 'curses', much longer
Windows: added winflexbison to travis-ci configuration to permit full build of levcomp and dgncomp
Windows: a bad chdir specified in win/win32/dgnstuff.mak caused full build to abort
Windows: the console.rc file had outdated information stating 3.6.3 when the official 3.6.6 binary had been built.
Windows: switch from using keyhandling dll's to incorporating the three variations (default, ray, 340) in sys/winnt/nttty.c
curses: cherry-picked selectsaved code from 3.7 for menu of save files
NetHackW: fix delayed rendering of cursor when using farlook
All of the fixes have been published on the public Git repository for the game. A more complete list can be found in the game's sources in doc/fixes36.7. As usual, a warning that some entries in that file may also be "spoilers".
Existing saved games and bones files from 3.6.0 through to 3.6.6 should work with 3.6.7, assuming that the same build configuration options were used with the same compiler.
Checksums (sha256) of binaries that you have downloaded from nethack.org can be verified on Windows platforms using: certUtil -hashfile nethack-367-win-x86.zip SHA256
The following command can be used on most platforms to help confirm the location of various files that NetHack may use: nethack --showpaths
As with all releases of the game, we appreciate your feedback. Please submit any bugs using the problem report form. Also, please check the "known bugs" list before you log a problem - somebody else may have already found it.
Happy NetHacking!
Hosted courtesy of alt.org.
Download: https://www.nethack.org/v367/downloads.html
Reply 1 of 3, by BitWrangler
woohoo, they haven't forgotten DOS https://www.nethack.org/v367/ports/download-msdos.html
Hope there's a benchmark mode now so you can see how your 3080 matches up to an IBM MDA card... 🤣 ... yes I am totally aware that graphics performance is mostly irrelevant to the game. (Though roguelikes with PC/XT binaries had helpful switches for print character during run on and off, or you could nearly count the frames on real slow cards.)
I might be able to get more into Nethack nowadays since I've recently been able to level my characters to the max in Moria, and it has got a bit boring.
Reply 2 of 3, by akula65
Patch file for building 3.6.7 with newer headers on macOS with some toolchains.
Reply 3 of 3, by akula65
Some recent updates on this version:
2025-04-18
Patch file for building with GCC 15.1.
2025-07-02
New Windows binaries are available that include the missing curses interface.
2025-07-02
NEW New Windows binaries are available that correct a packaging error from earlier today. If you downloaded the Windows binaries in the last eight hours, please download this update.
