First post, by MB17
Hello every one,
I'm an owner of this old laptop and want to connect a compact flash adapter. The problem is one of Pins is missing in a connect cable and on disk itself. Adapter has all Pins so i cannot connect it to the cable. Do you know which pin i have to remove? I attach photos of cable and Adapter. Pin that should be missing is circled in red.
