First post, by simoncfr
I have built and compiled dosbox-x on my macbook pro, and sure enough, debug mode works. However, once I tell it to start running I am not able to break back to the debugger.
Macbooks don't have Pause keys, though these are supposed to be F16; however, Option-F16 does nothing once the emulator begins.
I have tried using the remapper to map "pause" to another key, but that doesn't actually seem to help either. It behaves the same as F16 in the sense that Alt-remapped key does nothing, but control-remapped key sends a ^C signal... but that doesn't take me back to the debugger.
Any ideas? Is there something simple that I am missing? Or did I make a mistake when compiling?
Thanks for your help!
