First post, by envagyok
I build a 486 vlb pc with tekram dc-680c vlb ide cache controller.
How can i use with a hdd, and a 100mb ide iomega zip drive?
Tekram isn't see the zip drive, only hdd.
Or maybe better choose scsi vlb cobtroller with scsi zip drive and cd reader?
Reply 1 of 7, by jakethompson1
IDE ZIP drives are ATAPI devices, as are CD-ROM drives. It looks like this card came in two versions, one that also supports CD-ROM drives and one that doesn't.
Reply 2 of 7, by Babasha
envagyok wrote on 2023-02-22, 21:33:
I build a 486 vlb pc with tekram dc-680c vlb ide cache controller. How can i use with a hdd, and a 100mb ide iomega zip drive? T […]
DC-680C do not support ATAPI protocol - so, no ZIP support.
Need help? Begin with photo and model of your hardware 😉
Reply 3 of 7, by Vynix
Although, I seem to recall that there was an earlier IDE Zip100 drive that predated ATAPI by a few years, though whether or not they're easy to find, I can't say.
Model number for these is Z100iDE, they appear as a fixed disk to the computer they're connected to, which had caveats of its own (for instance if the host computer's (or IDE extension card's) BIOS doesn't support hotswappable IDE drives, you may have to reboot the computer every time you swap disks.
Not ideal but if you're just looking to use that Zip drive as a boot drive, it'll work transparently, but not so much if you want to shuttle files around on Zip disks.
If finding a Z100iDE isn't an option and you only have a ATAPI Zip drive, you can try and find a Tekram controller whose model number ends in CD, that indicates that the controller is ATAPI-capable. For instance, the DC-680CD.
Reply 4 of 7, by envagyok
Thanks everyone.
Maybe take an sb16 with cd rom connector can help?
Or a cd controller card?
Or put another atapi controller?
Reply 5 of 7, by Ryccardo
The former 2 are usually the original design passive-ish IDE cards, aren't them?
If that's the case, no problem - won't be bootable but it's not like your card would have been 😀
Actually, you should check whether they'll conflict with your good IDE controller - hopefully the "minor" card can be set to secondary address and interrupt while the VLB one doesn't act as one!
Reply 6 of 7, by mkarcher
envagyok wrote on 2023-02-23, 19:04:
Thanks everyone. Maybe take an sb16 with cd rom connector can help? Or a cd controller card? Or put another atapi controller? […]
Thanks everyone.
Your best option, if you have another VL slot available, is a VL IDE controller that can be jumpered to secondary port (170) and IRQ15. A dual-port IDE controller on which the first port can be disabled would do the job, too. For a ZIP drive, the ISA IDE interface on a sound card or CD controller is likely good enough, too. Make sure you get an IDE CD controller card, not a Sony/Philips/Mitsumi or something like that. IDE ports on sound cards and CD controller cards generally do not conflict with the primary IDE port on your Tekram controller.
Reply 7 of 7, by jakethompson1
mkarcher wrote on 2023-02-23, 21:12:
Thanks everyone.
If the OP is in the US, there are NOS cards on eBay called SMS 31-114. They have jumpers for all four I/O port ranges, and IRQ settings for 10, 12, 14, or 15.
