Enabling CD-Rom support
First post, by TomB
I'm trying to run Screamer 2. It runs but it tells me the CD-ROM is not in the drive. It is. When I run without VDMS it finds the CD but I don't have any sound.
in AUTOEXEC.VDMS i changed
rem lh %SystemRoot%\system32\mscdexnt.exe
to
this should enable CD-ROM support, right? or am I doing something wrong?
Thanks.
Reply 1 of 4, by eL_PuSHeR
Upgrade VDMSound to latest version, even if it's a beta. It works properly and you don't need to be editting any .ini file. Just right-click on the .VLP shortcut and edit it's properties.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by Kaminari
You could also replace mscdexnt with sapucdex (and make sure you've got a CD-ROM audio cable between your drive and sound board if your drive is set to analog playback).
Reply 3 of 4, by TomB
I'm running VDMSound 2.0.4 is that the latest? as for sapucdex.exe do I need to edit autoexec.vdms to reference that instead?
Reply 4 of 4, by HunterZ
I think there's a 2.1.0 beta.
