First post, by bassybeats
Hey Team,
I am having a tough time figuring out what is wrong with the Radeon R9600 Pro AGP GPU. The PC locks up and won't post with it plugged in ( verified the PC works with another card ).
Going through the 1.5V AGP pinout it seems pins 2 and 3 on side B are shorted to ground. Does anyone have any 'usual suspects' that I should be looking at to see what is shorting the 5v line? Or the next steps in testing should be, the card looks not that bad at all and I have already replaced the caps as they were bulging when I got the card.
Chers
Reply 1 of 7, by agent_x007
Check MOSFETs, if one of them is shorted it may cause this.
You will have to remove them one by one, since you don't have visual clues as to which one failed.
Another option would ba a failed cap, but since you replaced them I assume they are all fine (?).
Reply 2 of 7, by shevalier
bassybeats wrote on 2023-02-26, 08:33:
Its side "A" - AGP detect
+5V rail - on other side. Its connect to small electrolitic near AGP slot and traced via ferrite bead B17 to big capacitor C301 and Mosfeet.
Fuse F1 - its powering DDС in monitor. Its must be AMS1117/LM7805, but its cheap design. That's why is fuse )
    983.63 KiB
    109.04 KiB
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 3 of 7, by bassybeats
shevalier wrote on 2023-02-26, 17:22:
Its side "A" - AGP detect +5V rail - on other side. Its connect to small electrolitic near AGP slot and traced via ferrite bead […]
Ah so Side A is the back side? Fuse is fine and caps are fine, I will check the mosfets and AMS1117 and see what happens.
Reply 4 of 7, by andre_6
Hey Team, […]
Hey Team,
Chers
Probably a mere anecdote with no use for what already looks like deep troubleshooting, but to complement, when I got the very same card it refused to post through VGA but after many attempts I decided on a whim to try through DVI with an adapter and it worked. Later switched back to VGA and never had problems since...
Reply 5 of 7, by shevalier
bassybeats wrote on 2023-02-26, 20:59:
Steps to Repair Radeon 9600
First, check the integrity of the GPU crystal, especially at the corners.
Secondly - core power. 1.2-1.3V and memory 2.5-3.0V (depending on design. Memory can be powered by one or two identical regulators - Mem_VDDQ (for I\O) & Mem_VDD)
Third,replace all electrolytic capacitors.
The last step - look for Radeon 9800 Pro/XT))))
Or x850 XTX, but this almost unreal.
Reply 6 of 7, by bassybeats
shevalier wrote on 2023-02-27, 05:31:
Steps to Repair Radeon 9600 First, check the integrity of the GPU crystal, especially at the corners. Secondly - core power. 1.2 […]
So did some more digging. I was mistaken with the 5V line being shorted, mixed up side A and B on the pin out.
BUT, the two green caps by the fan header are shorted across the pads. So I think that is my issue, I just cant find the short. Could still be the die itself. I'd gladly take a 9800 Pro XT if I could find one without selling a kidney!
Reply 7 of 7, by shevalier
bassybeats wrote on 2023-02-27, 08:09:
Resistance of RV350/360 is 9 Ohm on "Diode" range.
This can be confused with a short circuit
like this?
    402.6 KiB
