First post, by ediflorianUS
Can anyone help,me, fix
a Fujitsu Lifebook B142 (from cc 1999-2000 with 300mhz Celeron CPU)?
Darn thing won't Post.(SO NO P.O.S.T.) (it just sat in a locked steel box) last time it worked. (led is on , HDD spins up).
I have a B112 same issue , got that one for parts.
I am thinking it's a series defect.(affecting entire series of 8.4" japanese B1x2 laptops).
Changed the 3v bat , tried clr cmos with +/- short. No avail.
My research lead me to possible culprit Ram or VGRAM or bios?
Anyone know more than me , about this issue? (hdd IDE getting power , I checked V 16 and 5 v so I am not sure ,but don't think anything is burned ).
L.E. Last time it worked for sure is when I photo'd it on April 2021
My 80486-S i66 Project
Reply 1 of 12, by GenkiMan_Lx
Hi,
Got a B142 it was working and then from nothing it froze and now it has the same problem you are reporting.
Did you found out any possible repair?
Reply 2 of 12, by PD2JK
Maybe BIOS reflash works. Some mainboards I have got my hands on show similar problems. Plain dead, but after flashing the BIOS with an external programmer they sprung to life again.
With laptops it is more challenging to do this. If you can find a BIOS ROM file, then you need to get to the BIOS chip as well and hope it's not soldered on to the mainboard.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 3 of 12, by CharlieFoxtrot
I would check MB for leaky capacitors, especially those for VRM. Also measure voltages from PSU, I assume this one has internal one instead of external brick. PSU may have capacitor or regulator issues and it is not working properly.
When diagnosing electronics, it is important to rule out the basics, that is power delivery. If you have oscilloscope, you can also check that the crystal is working (CPU has clock) and try to find and check reset signals, memory lines, video circuitry etc. and see where there is and isn’t life.
If those things seem OK, then it may be one of your suggestions or something like a cracked solder joint somewhere.
Reply 4 of 12, by MikeSG
Can you plug an external monitor to it, does anything show up?
Reply 5 of 12, by kotel
Does the caps LED respond to capslock key press?
You say you've got me outnumbered
I say you've evened the odds
You doubt the strength I hold within
Just one bounce back is all I need to win!
Reply 6 of 12, by ediflorianUS
GenkiMan_Lx wrote on 2025-09-10, 04:02:
Hi,
No , it's driving me up the walls , I can't locate the RAM of GPU of the NEO on the Motherboad. (that seem to be the issue) however can also be a blown capacitor somewhere but because it starts and powers the Hard Drive and charges I am unable to fix it (I have 2 of them with problem)
I can dump the bios (may be corrupted but highly unlikely) if you wish.
MikeSG wrote on 2025-09-10, 07:44:
- Sadly NO. NO POST.
kotel wrote on 2025-09-10, 09:25:
- There is NO CAPs Led-light. (just the middle LCD screen) not showing up there , and not loading OS. Just chargeing and you can only know it's alive it you have a hard disk(spinner) in there that spins up (doing nothing).
Any HELP IS WELCOMED (Sorry It took this long to write).
Reply 7 of 12, by kotel
Ah, it's one of those fujitsu's with the LCD status LEDs thingy.
On a later lifebook s4572 there is a "kill switch" located at the back. It cuts the power to the entire laptop, leaving only the battery charging circuit active. If it's on the laptop boots up. Maybe yours has that switch too?
nvm your powers on but no POST, can be bad BIOS or CPU (these also can die for no reason).
Check CMOS battery next I guess. nvm you also tried this. Also check for a green pack of Varta Ni-MH cell pack. Those really like to leak (learned it the hard way on said laptop).
Also could be unsupported RAM since mine was picky about 256MB sticks. But this is unlikely since you've probably tried this by now.
So to summarize: bad BIOS (probably some PLCC32 EEPROM) or bad CPU.
Disassembly guide here.
Reply 8 of 12, by ediflorianUS
kotel wrote on 2025-10-16, 16:26:
Ah, it's one of those fujitsu's with the LCD status LEDs thingy. On a later lifebook s4572 there is a "kill switch" located at […]
Sorry to disappoint , it had a 3v cell battery , it's pretty modern config. (yes it has a button but it powers up , laptop died in a metal-shielded-locked-box).
Battery(3v) was changed before the incident (so it worked on the new battery for a while), the original main battery is working and charging.
Ram is same toshiba as I used since I have it (SDR 128 + 64mb onboard) - check foto
it has a IOR bios.... I can probably dump the content but not sure it helps
Reading many stuff online it seems toe be a model issue regarding the GPU RAM (witch is not locate-able on the motherboard , underneath is just the SDR).
Do you have a good bios I can try? I lost my files with bios I had dld when they were still online (I only have the drivers now).
Reply 9 of 12, by kotel
The GPU could use the integrated SDR. But since pressing CAPS LOCK didn't make it's own status symbol appear on the status bar thingy, I suspect something deeper is going on... Normally even with a bad BIOS the laptop should respond to CAPS keypress. Maybe fujitsu did something funny again and chnaged they way this works.
As for the BIOS, I can't find it even on the old fujitsu driver page here.
Reply 10 of 12, by ediflorianUS
[quote=kotel post_id=1383366 time=1760770591 user_id=53328
Anyone know where the bios chip is located?
I can only find a big chip on backside near the Chipset
P012849B-sticker- multi-pin (probably) Flash Chip - can this be the bios?!
the IOR IRF7416 chip is a mosfet , glad I did not put a chip reader on that....
Reply 11 of 12, by onethirdxcubed
The chip with the sticker could be NOR flash memory. Intel's Flash from this time is known to be somewhat unreliable. But since the status LCD doesn't work either it could also be an issue with the embedded controller. Do you see any corrosion on the board, Green crusts or dried dark liquid?
Reply 12 of 12, by ediflorianUS
onethirdxcubed wrote on 2025-12-01, 18:16:
Status LCD works, hdd spins. (I just not getting the caps icon on the status lcd) laptop charges powered-on & off.
Cleaned all the main-board with contact claner + checked all caps (no short , all seem fine.) I don't know what else to try, I can't locate the bios.(for a write/dump)
(Next time when I open her up I will reflow all contacts on the crystals.... there are many).
