SB16 / pc speaker
First post, by xbit
Some of the old games I like are PC speaker only, like EGATrek. My PC speaker is very quite so I hoped to hook it up to my SoundBlaster CT2970. But, it looks like i have a cheaper model with out a PC Speaker connection, correct? Or would the AUX2 work? And if so my only option looks to be another soundcard?
The X-Bit BBS @ https://x-bit.org/info
Reply 1 of 8, by Ryccardo
You can most likely use that analog input for PC Speaker (after of course unmuting it and setting the volume) but not directly, the conventional PC Speaker has 5 V always live and a switched ground to feed the sound into (out of?) it, so you'd need some added electronics to turn that into a line level signal; shouldn't be very complex but I'm not the most knowledgeable person on this matter...
Now whether it's worth it compared to changing your soundcard (or amplifying the motherboard output, or switching to a more sensitive speaker, or adding the missing components to get a PC Speaker input on the sound card) is another question!
Reply 2 of 8, by xbit
Yeah, lots of options but I think the EZ route may be to find another card with the correct input. Kinda cheap on eBay anyway. Thanks Ryccardo!
Reply 3 of 8, by Pierre32
Another option is just to look at how your speaker is mounted. I had one that was clipped into a plastic cage, completely gutless hanging in the air like that. I hard mounted it against the metal chassis instead, and the difference was huge.
Reply 4 of 8, by Darmok
At the link you will find a complete solution, and on the attached diagram a very simplified, but noisy, version.
PC Speaker Sound Device. Need advice.
Reply 5 of 8, by bogdanpaulb
If that's the case he can mount the actual passives needed and connector on his board , the smaller square is the actual input for the pc speaker signal .
Reply 6 of 8, by xbit
bogdanpaulb wrote on 2023-03-07, 12:57:
are you saying i could just solder on the connections needed like other cards have? so I could go from motherboard to soundcard?
Reply 7 of 8, by xbit
and btw, thanks all for the help.
I should note that this little thing from amazon helped, but still quite quite. I remember my 486sx 25 back in the day just blasted its pc speaker sound.
Reply 8 of 8, by Darmok
xbit wrote on 2023-03-07, 15:56:
Yes, component values should be:
R43 - 390 Ω
R40,R41 - 47 kΩ
C81 - 10 nF
C88 - 4.7 uF
You need to check where the trace from C88 leads, it should go to a resistor, which is also probably missing and should be 20 kΩ or so.
