First post, by seiko4169
Hi all, I was hoping someone might have a bios dump or old chip for my Chaintech 7AJA0/100. It's no longer booting or successfully arriving at the POST.
I have tried different memory, cpu and AGP cards. No beep, no video out only spinning cpu and agp card fans. I've cleaned the cpu, gpu and memory pins, all looks good but I can't get this to post. I've reset the BIOS but I actually think this may have made matters worse as the power reset does no longer work. Only a hard power on / off will start the board. The CHAINTECH red light does come on (which is correct). If I try to set a jumper to control the CPU speed (its a locked CPU) then the CPU warning light correctly comes on however no video out and no beep.
My motherboard testing card simply shows 0000
I'm contemplating replacing the capacitors on the board next as one looked a LITTLE dodgy but this might be a red herring.
Ideally I'd like to replace / reflash the BIOS so I can rule that out too.
If you have one I'd be very thank full.
