First post, by GabrielKnight123
I'm looking for an adjustable bar with feet on both ends to go under my desk at the moment I'm using an LCD monitor I'll use my heavy CRT later when I get this support bar, I've got a few things already on the desk but the CRT in my view needs support. I don't know what they're called but I guess they exist for use in the industry somewhere has anyone seen these?
Reply 1 of 9, by Hezus
There are these adjustable table legs, that are commonly used in boats, campers and RVs: https://www.amazon.com/Boat-Table-Pedestal/s? … +Table+Pedestal
I have never had to use any additional support for CRTs on any of my tables, though. And I've had plenty of rickety old tables or cheap ones from IKEA. They've all held up CRTs just fine. They are heavy compared to LCDs but not *that* heavy that you'll need industrial grade equipment to use them. If your table is indeed that shoddy that it can't hold a CRT, then maybe a better table is worth the investment 😉
Visit my YT Channel!
Reply 3 of 9, by GabrielKnight123
The bunnings one is more in my price range I've looked at bunnings trying to see if there are feet with bolts similar to the leveling feet on a washing machine my idea is to screw a foot leveler to some round pine so it can be twisted to take up the slack and weight, thanks Hezus they look good but some look like there is a pin and hole to get manufactured default heights I'm not sure those would work
Reply 4 of 9, by Pierre32
GabrielKnight123 wrote on 2023-03-11, 08:54:
Yep, if you sort that "furniture leg" section by lowest price you will find some things like that:
https://www.bunnings.com.au/products/building … =PriceAscending
Reply 5 of 9, by GabrielKnight123
Pierre32 wrote on 2023-03-11, 09:00:
Those 3/8" vertical leg plates would go with a level bolt that's just what I need 😄 thanks Pierre32
Reply 6 of 9, by DiyaMosley
I was in a similar situation when I was setting up my home office and needed a sturdy support for my old CRT monitor. I ended up finding a few adjustable monitor stands that could hold the weight and had feet on both ends, so they were stable enough for my setup. I didn’t know what they were called at first either, but after a bit of searching, I found the perfect one.
Reply 7 of 9, by Major Jackyl
I bought these crappy Ikea tables probably 10 years ago, and I only put two towers on each and they had a horrible sag the whole time I used them. I recently started using one again any found something at Axman (local parts/crap/stuff store) for $10 that fixed it.
The attachment 20250120_165738.jpg is no longer available
I googled it (can't see the label from this side) as "sub-floor screw jack", which turns up some VERY expensive solutions, but there ARE some cheepies.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 8 of 9, by DiyaMosley
DiyaMosley wrote on 2025-01-20, 21:03:
It was a game-changer for my desk. If you’re still hunting, I recommend checking out some blogs for tips and product ideas—more info here has been super helpful for me when I was looking for office gear.
Reply 9 of 9, by ratfink
A short acrow?
