First post, by FazzaGBR
- Newbie
In the Pentium 100 desktop I recently purchased there is an Aztech CDA 468-03ISE optical drive in it that still reads discs OK but is quite noisy - it's making a grinding noise when spinning the disc so I'm assuming whatever grease/lubricant was used 25ish years ago has dried up!
Have any of you serviced an old CD-ROM drive before, if so what type of grease/lubricant did you use and what part(s) need it applying to?
Thanks.
My personal website blog: https://www.retrocomputing.co.uk/ and my new Retro Computing YouTube Channel: https://www.youtube.com/channel/UCL8UT2gm3EvNl2tvomN7reg
