First post, by sangokushi
I have one of this PROMISE FastTrak S150 TX2plus PCI SATA Controller Card, which is PCI 2.3 compliant
https://www.newegg.com/promise-fasttrak-s150- … N82E16816102016
Just wondering if I can use it in an Asus P2B motherboard? I think the PCI slot only supports PCI 2.1
I assume I can use a PCI 2.0 adapter in a PCI 2.1 slot. Not sure if PCI 2.3 adapter is backward compatible.
Reply 1 of 6, by Grzyb
"PCI 2.3 compliant" may mean MSI interrupts, not supported in PCI 2.1
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 6, by Horun
Yeah. The manual even says "32-bit PCI slot (must be PCI 2.2 or 2.3 compliant)"
Reply 3 of 6, by sangokushi
Thanks @Grzyb and @Horun, I will try to use another controller card.
Reply 6 of 6, by jakethompson1
sangokushi wrote on 2023-03-14, 02:13:
@jakethompson1 Is there a specific manufacturer you recommended? I google searched and this Syba adapter also PCI Revision 2.3 compliant
https://www.sybausa.com/index.php?route=produ … &product_id=865
Not sure, I use a cheap $10 adapter from eBay on a board with a 440BX chipset. I believe such boards are only PCI 2.1 compliant. That chip is popular because Windows 98 drivers.
