First post, by Berzerkula
Greetings crew,
I've gone through homebrew M68K and Sergey's Xi8088, and I wanted a homebrew 386. Outside of M396F, I thought an SBC of a 386DX would be neat. Then I stumbled across this:
https://alexandrugroza.ro/microelectronics/index.html
I have latest PCB's of most of the project. If anyone is interested, let me know. PCB's are available and if you need parts, let me know. I haven't built one, but plan to, soon. Letting the community know they are available. One for me and 9 for others.
Backplane is being fabricated, but I also have the 4Mx9 70ns 30-pin SIMM PCB's and the ISA signal view interface. SIMM sockets are on order, still need to check the rest of my inventory. If anyone is interested, would be neat!
Only break even on PCB's and no profit. I sourced parts, so if need them, will increase project cost. Pictures show fitting SIMM sockets for future order.
-William
You feel a whole lot more like you do now than you did when you used to.
Reply 1 of 7, by GigAHerZ
I've seen one 386 motherboard that used 72pin ram. Maybe it would make more sense to use 72pin ram and forget the 30pin simms, if the board is created today?
A little about software engineering: https://byteaether.github.io/
Reply 2 of 7, by maxtherabbit
looks like a pretty solid design, let's see how it holds up under heavy processing load
Reply 3 of 7, by Berzerkula
GigAHerZ wrote on 2023-03-14, 07:42:
Did 386's use 72 pin SIMM's back then? Pray tell me when they did. Boards which used 386 or 486 with accompanying hardware may have. But you wouldn't see a 386 using 72 pin SIMMs.
Reply 4 of 7, by Berzerkula
maxtherabbit wrote on 2023-03-14, 14:00:
Want to build one? You can see how it does after you build one.
Reply 5 of 7, by GigAHerZ
Berzerkula wrote on 2023-04-05, 07:43:
Yes, i have one non-functional pure 386 board with 4x72pin ram sockets. It's very unfortunate that it was so corroded that it was impossible to restore. 🙁
Reply 6 of 7, by rasz_pl
one example Re: The Retro Web project - a better stason.org/TH99 alternative
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 7 of 7, by maxtherabbit
Berzerkula wrote on 2023-04-05, 07:48:
I do, but I'd like to wait a while to see how it does for others first. Not much of a bleeding edge guy myself
