First post, by majestyk
I have been tinkering a bit with this mainboard recently. I added the headers for a 2.9V VRM, upgraded L2 cache with an additional COAST stick for 512K in total and flashed the latest BIOS.
I can now use dual voltage CPUs like the MMX233.
Next I installed a socket 5 / socket 7 interposer with integrated step down regulator that can provide 2.0 and 2.2 V. The system starts with a K6-2+ 570 @ 6 x 66 MHz and runs fine.
1.16 MiB
Of course the BIOS knows nothing about write allocation (it detects the CPU as "80486DX-S @ 66 MHz) so I tried enabling it with "6k6v3" under DOS but it won´t do the trick.
I wonder if the 430FX chipset might be the obstacle here or are there other reasons?
252.75 KiB
This problem isn´t new
https://www.philscomputerlab.com/k6-2-2-3-resources.html
(but no solution there, "mxk6opt" doesn´t work either.
Reply 1 of 9, by Horun
The BIOS is most likely the limitation. The board would probably run a standard K6 OK but not a K6-2 (K6-2 first came out late May 1998, your cpu is from 2000+/- and the latest BIOS is 08/21/97)
Reply 2 of 9, by majestyk
Thanks Horun, you just inspired me to try a regular K6-2. It´s also detected as "80486DX-S @ 66 MHz", but write allocation c a n be turned on with "setk6d" now.
Same goes for a K6-III.
Still not sure what the reason might be.
Reply 4 of 9, by Chkcpu
@NostalgicAslinger, Thanks for the heads-up. Yes, I believe I can help with this BIOS.
@majestyk, Looking into this 08/21/97 BIOS is see basic K6support, so patching for K6-2/-III/-2+/-IIII+ support is possible. This includes Write-Allocation support for the CXT core.
Let me know if you like to have this BIOS patched. I will put it on the list then. 😉
Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 6 of 9, by Chkcpu
majestyk wrote on 2023-03-17, 16:56:
Hello Jan, that would be great! […]
The latest BIOS I found is this one:
5te2.zip
Thanks in advance!
Hi majestyk,
Thanks for the latest SY-5TE BIOS.
The patched version of this BIOS is ready and I send you a copy by PM so you can test it.
When tested, I will put it on my Unofficial K6-2+ / K6-III+ page and up here as well. 😀
Jan
Reply 7 of 9, by Chkcpu
majestyk wrote on 2023-03-25, 13:58:
K6-2+ and K6-III+ CPUs are detected correctly now, but as "375 MHz" while running at 6 x 66 MHz. (Speedsys, cachechk etc. id the […]
K6-2+ and K6-III+ CPUs are detected correctly now, but as "375 MHz" while running at 6 x 66 MHz. (Speedsys, cachechk etc. id them as 398.40 MHz.)
All 3 caches are working fine according to "cachechkv7".
Write Allocation is enabled according to CTCM 1.7 and the memory write graph in Speedsys.
I was testing with 64MB RAM.
Hi majestyk,
Thanks for testing the SY-5TE patch J.1 BIOS. Great that the CPU detection and Write-Allocation work as expected now. 😀
To fix the 375/400MHz CPU speed issue, I've made a new patch J.2 BIOS version and send you a copy via PM.
Please test this new J.2 BIOS, I expect it will fix the speed display issue.
Cheers, Jan
Reply 8 of 9, by majestyk
Thank you, Jan!
I can confirm the new "j2"-version detects K6-2+ and K6-III+CPUs correctly now as 400 MHz (@6x66).
This formerly crippled mainboard can now deal with a variety of advanced socket 7 CPUs (provided a suitable VRM is installed).
Reply 9 of 9, by Chkcpu
majestyk wrote on 2023-05-14, 18:59:
Thank you, Jan!
Great! Thanks for reporting back so quickly. 😊
I'm planning an update of my Unofficial AMD K6-2+ / K6-III+ page tomorrow and will add the SY-5TE patch J.2 BIOS then as well.
Jan
