First post, by xbit
I have a Sapphire Radeon HD 6850 that was given to me a very time ago because the fan stopped working and he wanted to get a new GUP anyway. Just looked at it for the first time and it looks like an easy fix. That said, the wire (guessing its the ground) is very thin.
I'm thinking it would just be easer to just get a 4 pin extension and splice on a new section? The current 4 pin doesn't have a lot of length to play with.
Looks like this would be a nice bump to the current HD 5770 that i have slotted for the core 2 Duo E7500 build that i'm working on now: http://x-bit.org/retroduo/
    67.2 KiB
    1.32 MiB
The X-Bit BBS @ https://x-bit.org/info
Reply 1 of 2, by xbit
I'm finding it difficult to un-grip the leftover wire.. <g>.
    145.75 KiB
    847.21 KiB
    1.07 MiB
Reply 2 of 2, by xbit
Yeah, on amazon they have $5 4-pin adapter cables that allows you to connect standard 4-pin PC fans to the gpu's mini 4pin. Might be easer and overall more secure to get one, cut and splice it on to the GPU.
    25.74 KiB
