Asus PVI-486SP3 v.1.22 and 66MHz FSB
First post, by dj_pirtu
Figured out yesterday that VT8228 clock chip can do 66MHz FSB so tried and it worked.
CPU is late i486DX4/100 WB Enhanced and takes 2x66MHz=133MHz with no problems. (Tried 3x50MHz=150MHz on that QDI V4S471 but didn't make it to DOS)
Cache needs to be slowed down a little and CPU to PCI Post Write needs to be disabled or strange things will happen. If enabled and when in heavy CPU load, screen stops updating and DOS4GW gives some kind of real mode -error. When disabled it just kills PCI-speed (display card, Cirrus 5446 PCI) from 40MB/s -> 20MB/s.
My other system QDI V4S471 with CX5x86 (2x50MHz) is just as fast in memory operations, it's cache timings are fastest and memory 'faster'.
But still, that i486DX4/133 is quite fast.
Anybody else have tried 66MHz clock on this mobo?
Reply 1 of 38, by dj_pirtu
Benchmarks with CPU to PCI Post Write enabled.
Reply 2 of 38, by nuno14272
Not bad.. I'm in the process of getting up my system with the same board and a X5-133... would be already running if not the exploding tantalum near power connector...pfffff
let's see what my numbers are.
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 3 of 38, by dj_pirtu
Tried yesterday my Cyrix 5x86/100 at 2x66 but didn't even post. Not so surprising, it's damn bad overclocker, need 4V to get 120MHz stable. Too bad that 486SP3 don't have 60MHz FSB option.
Reply 4 of 38, by rasz_pl
you could always mod external clock generator 😜
$3 "25MHZ Si5351A I2C Clock Generator Breakout Board 8KHz to 160MHz" + arduino or some serial to I2C converter to program frequencies
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 6 of 38, by rasz_pl
choice of 50 53 60 66 MHz doesnt sound that appealing for overclocking compared to $3 https://learn.adafruit.com/adafruit-si5351-cl … eakout/assembly with precision down to single hertz https://rfzero.net/documentation/tools/si5351 … frequency-tool/
Reply 7 of 38, by Jasin Natael
I will have to boot up my system and do some tests.
Same board, I'm running a Cyrix 5x86 @ 120MHz (40x3)
Reply 8 of 38, by WJG6260
Interesting. This inspired me to check the ASUS VL/I-SV2GX4’s MX8315PC clockgen datasheet. Low-and-behold, it has 60MHz and 66MHz options too. Intriguing stuff.
Does anyone know if there is a PCI divider on this board, like the LS-486E?
EDIT: Your Intel DX4 at 2 x 66MHz seems really fast. It’s not too far off from an Am5x86-160MHz, in SpeedSys at least. Quake also is really impressive per-clock. I wonder if there’s any headroom to go further on these Intel chips?
-Live Long and Prosper-
Feel free to check out my YouTube and Twitter!
Reply 9 of 38, by BitWrangler
You can try some different PCI VGAs in there, what's "fast" at 33Mhz PCI isn't necessarily the best overclocked a lot, some "slow" cards have conservative timings that mean they clock to the moon. In particular if you wanna look for VGA chipsets that appeared on PCIx cards without need for a buffer chip, then those on 32bit PCI should have some headroom.
Reply 10 of 38, by dj_pirtu
WJG6260 wrote on 2023-03-23, 15:43:
Tried 150MHz (3x50) with slightly higher voltage but got only post and then hangs. With default voltage won't even post. 133MHz works flawlessly with default voltage.
I'm really struggling to get my Cyrix 5x86 stable @120MHz, needs 4V voltage and still it's on the edge. This i486DX4/133 is actually almost as fast so I'm thinking if I just take Cyrix out and use this DX4 instead.
Reply 11 of 38, by CoffeeOne
Hello,
Do you have jumper settings for the SV2GX4 for 60MHz and 66MHz?
Reply 12 of 38, by nuno14272
Sorry to hijack this thread.
I have the same board. And i'm having a strange problem. (cpu is a X5133). Jumpers are set fine.. the thing is.
I'm using a isa dignostic post card to help. So:
1) power on.. nothing.. post card --:--... but i can see reset led always on.. hmmm
2) put my ginger in the bios chip just touching and reset led goes off, and clock led goes up.. so power on again and it boots... yuuupii..
3) take my finger and nothing again..
4) take the bios chip off.. clean it with spray.. and the socket.. put it back in... everything is making contact..
5) power on... nothing...
6) my finger again, once twice, reset led off, clock led on.. power on again, working..
WTF ?
7) take the bios chip out again.. put it again.. only works with my fingers..
IS THIS BOARD A WOMEN???
come on.. what the fuck is going on.. is not bad contact within the bios chip.. seems like a gounded problem.. my habds touch the metal case, and the bios chip and , i dont know, it gets connected..
any ideas ?
1| 386DX40
Reply 13 of 38, by Jasin Natael
dj_pirtu wrote on 2023-03-24, 05:23:
I had some stability problems with my Cyrix 100gp at 120 (40x3) with my only VLB video card. A Trident something or another, but once I put in a PCI video card my problem went away. This is at stock voltage as well. The PCI card I am using is a Jaton Tseng Labs ET6000, but I also tried a ATI Rage XL and a Trident GUI9480 I THINK was the model. All PCI cards seemed to be more stable than the VLB card.
Reply 14 of 38, by dj_pirtu
Jasin Natael wrote on 2023-03-27, 13:35:
Actually I'm using QDI V4S471 motherboard with the Cyrix, so only VLB there. Cyrix is stable as long voltage is 4V at minimum, 3,9V is not enough. There's lot of Vdrooop so it needs to be little over 4V.
Yeah, it's a lot but stays cool. Works as long as works.
Reply 15 of 38, by Comos
I have several boards with this revision, but I played with a AM5x86-133 @66FSB there and that didn't want to POST, so I sticked with playing with my UM8886/8881 mobos with better success.
Reply 16 of 38, by Jasin Natael
dj_pirtu wrote on 2023-03-28, 07:40:
Oh ok, I must have gotten confused. Sorry about that. As long as it stays cool I wouldn't worry much about the voltage.
Reply 17 of 38, by The Serpent Rider
It's a shame that this board can't use EDO modules. Hard to find good FPM that will work at 66MHz.
Reply 18 of 38, by nuno14272
The RetroWEB says it supports..
1| 386DX40
Reply 19 of 38, by The Serpent Rider
Only specific chipset revision has EDO support.
