Linux Install Problem
First post, by Guest
I'm pretty much a n00b at Linux and I'm wndering if anyone can help.
I try installing but it does nothing. When I try to install from the console it gives me this.
[root@localhost root]# rpm -ivh dosbox.rpm
warning: dosbox.rpm: V3 DSA signature: NOKEY, key ID 6b8d79e6
error: Failed dependencies:
libSDL_net-1.2.so.0 is needed by dosbox-0.60-0.rh90.dag
I have no clue whats wrong. Especially since I just installed the SDL package.
Reply 1 of 1, by HunterZ
SDL_net is most likely a separate package from SDL.
