First post, by Robin4
- l33t
Does anyone have a good tip for me, to remove those stains in the metal of an older IBM look a like XT power supply?
I dont know what to use so i can wipe the most of it away.
What is the finish? It is chrome?
Pics?
Chrome like
I use a little bit of spiritus. Helped a little bit.. Not perfect yet.
Try Window cleaner that has some ammonia in it, I use Windex to clean the chrome+stainless on my microwave. Takes a bit o elbow grease but works ok....
There is semi-chrome which is meant to polish chrome. You will end up with micro-scratches though.
My guess is that the stains are rust but they could be something else as well.
Pictures would help.
