First post, by Brawndo
So I have a 24X CD-ROM in a socket 7 system with a stuck tray, and I don't have any experience fixing those beyond sticking a paperclip into the ejection hole, which doesn't work in this case. I've disassembled the unit to see if I can find what the issue is, but I'm not sure. From what I can see, when I press the eject button, the black center piece which carries the laser assembly does not lower all the way, and the tray doesn't even try to eject. Searching the web for how to fix a CD-ROM stuck tray has been useless as every article only references the damn ejection hole, and I need a more in-depth resource for troubleshooting the internal mechanics to figure this out. Does anybody have a good reference, or any ideas what I can look for or try?
If pictures would help I can post those later.
Edit: I should add that in my testing, I verified if I manually start the plastic slider underneath the tray to just barely start the tray opening, when I power on the PC the tray opens the rest of the way on its own just fine. Also, if I fully open the tray manually and power the PC on, it closes on its own just fine. It seems that whatever is responsible for actually starting the tray opening automatically is having an issue.
Reply 1 of 8, by Rwolf
Hard to say without pics, but those few CD players that I have had similar problems with, have suffered from cracked nylon cogwheels, specifically the smaller wheels on the motor axle seem to have been prone to this, and the motor axle just spins inside the wheel. Sometimes it's just a simple mechanical fault like that - and a cogwheel can be replaced.
Reply 2 of 8, by jmarsh
Brawndo wrote on 2023-04-16, 14:52:
Sounds like a belt has stiffened up. Instead of being round they take on an oval shape (matching their idle position) and the motor doesn't have enough force to get it rotating.
Reply 3 of 8, by Brawndo
jmarsh wrote on 2023-04-16, 17:01:
I did look at the belt and it is a little floppy and stretched looking, but wasn't sure if that would be an issue considering it still opens fine with a manual start and closes.
Reply 4 of 8, by Repo Man11
The only solution I've found for this issue is to gently scrub the drive side of the belt with a Scotch-Brite pad. Be sure to also clean the drive and driven pulleys with alcohol, and use silicone grease on any moving components where the original grease has hardened or disappeared.
Reply 5 of 8, by sneeker
If the belts stretched, take it out and boil it in some water, then dry and refit it. It shrinks the belt and the tray works again. This works fine on the original xbox which has problems with the belt stretching
Reply 6 of 8, by Brawndo
In case anyone is interested, I spent some more time fiddling with it, ended up ordering a bulk pack of replacement belts on ebay since it was only a few bucks, replaced the belt and it's back to working condition! Cheap and easy. Really glad it worked out as it's the original CD-ROM from 1997 and I'd like to preserve it.
Reply 7 of 8, by jesolo
Brawndo wrote on 2023-04-23, 18:47:
Which seller did you buy from? Looking to secure a couple of drive belts myself. Not just for CD-ROM drives but also some old tape decks.
Reply 8 of 8, by Brawndo
jesolo wrote on 2023-04-23, 22:25:
Bought this, but looks like they're out of stock now:
https://www.ebay.com/itm/304491481308
This looks like exactly the same pack, from a different seller:
https://www.ebay.com/itm/265814486324?hash=it … %3ABFBMoIarvPZh
It's way more belts than I'll ever use, but nice to have a ton of different sizes so you can find just the right fit.
