First post, by SuperLuke2003
Hi!
i rescued a siemens laptop from work which functioned Electrically however suffered from cracking plastic around the hinge joints.
while a friend has fixed the damaged plastics through fusing them with heat, i have since forgotten how the entire LCD assembly goes back together,
i only took one photo of the entire assembly BEFORE dissasembly,
if anyone has a similar machine or a service manual. that would be massively helpful
in terms of another machine if somebody could take a picture of what the assembly looks like without the front Bezel that would be amazing
i have attached pictures of the assembly and a metal bracket i am not sure where goes.
