Voodoo 1 PCI bracket
First post, by bigbeigebox
I've managed to get a working original voodoo graphics card for a good price, only it doesn't have it's bracket (the metal part that surrounds the VGA ports and screws into the case - not sure if that's its technical name)
I've think I've found a PCI serial card where the serial ports look like they match up to the voodoo's VGA positions, but before I take a punt on that I was wondering if anyone knows where I can get hold of a new bracket, or something that will definitely fit?
My last resort will be to buy a blanking plate and drill/file the holes for the VGA ports
Reply 1 of 1, by Sphere478
Calamity lime made a pcb bracket project. (Bracket made of pcb)
Or
You could use a blank bracket and a small file and drill set to make your own.
Others will come up with other ideas also I’m sure.
Sphere's PCB projects.
