First post, by strongly-typed
Hello,
I am trying to modify a C&T 65550 VGA BIOS to always display to CRT and flat panel.
I dumped the EEPROM and found BMP32K50.EXE tool from Advantech:
https://www.advantech.com/emt/support/details/faq?id=1+FY+68
BMP32K50.EXE works fine with the files from Advantech.
When I use my BIOS file (1 MBit) I get multiple errors:
"BMP structure is 0A33h bytes long. BCF file describes 1170h bytes."
I added the file for you to reproduce the error.
Do you have any clues how to edit the BIOS file to enable CRT and flat panel output directly from boot?
Thank you so much.
BR
