First post, by tietze
Hi, I've bought a used Asus P2B 1.02 and there is a missing component missing the PS/2 port. Apparently this (and maybe other things) results in keyboard error/ lots of beeping (attached ps/2 keyboard works on other computers).
Could anyone checkout the component on their own board so I can order/find a new one to soldered in place?
The attachment p2b-missing.jpeg is no longer available
The best photo I found of a board with the component is this:
The attachment p2b-notmissing.jpeg is no longer available
Best regards,
Jørgen.
Reply 1 of 3, by bogdanpaulb
It's a ferrite bead inductor for emi filtering https://www.google.com/search?q=ferrite+bead+ … 036RO1036&hl=en, you can salvage it from any atx motherboard, it's placed between the 5v fuse and the ps/2 connector power pins and it provides 5v dc trough it for the keyboard/mouse.
Reply 2 of 3, by tietze
Thanks - had a few tries identifying a ferrite bead - and now the ps/2 keyboard port is working 😀
Reply 3 of 3, by Horun
Good job ! looks a screw driver mishap, those beads are brittle and do not take much to break....
