First post, by Jackhead
Any suggestion what Soundblaster i should choose?
I think about a SB16 but what model? I not really want a AWE. But above the Pro 2.
Good OPL3, and midi would be nice. And it should be ISA because no more pci slots left 😀.
Reply 1 of 5, by Shponglefan
Sound Blaster 16. Though keep in mind that depending on the model / DSP version, you will potentially encounter different types of issues. I'd recommend looking at this list when selecting any Creative Labs card: Sound Blaster: From best to worst
Personally my pick for a system intended for that era (assuming mid 90s), I'd probably just go for an AWE64. I currently have a similar build with a combination of a GUS Extreme and AWE64. The latter provides SoundBlaster 16 and AWE32 compatibility, while the former covers GUS Classic and SB Pro. Though admittedly I'm not fussed about genuine OPL, since by that era of gaming FM synthesis was less relevant. By that point audio was mostly digitally recorded including music.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 5, by Jackhead
Thanks for the link! i found a CT1750 with dsp 4.05 . For what chip was the empty socket over the dsp again?
Reply 3 of 5, by wbahnassi
ASP chip, you're not missing that much without it though.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 4 of 5, by JayAlien
There is some great info on the asp/csp chip here:
http://dosdays.co.uk/topics/sb16.php
This site contains so much useful information if any of you haven’t visited
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 5 of 5, by badmojo
CT2230 or CT2290 are the nicest SB16's I've personally come across, but as always it's important to set the mixer up right for the best results, and use line-out 👍
I steer clear of the Vibras because of hanging notes and the simplified mixer - from memory you can't alter the gain, which is a loss (pun intended)
