First post, by BiggerJim
This is my first post and not sure if this is the best place, but here goes...
I need to read some Sony DTF tapes. I have a DTF tape drive, and occasionally need to send it low-level commands like "recover" to make the drive mount tapes that were ejected improperly. The manual tells of some Sony tape software called "scsitool.exe" but I've been unable to find it (and there's a RS232 utility called remo.exe I can't find, either).
I'd also like to update the firmware from its current version (1.00) so if anybody has some firmware files ....
Any suggestions gratefully received.
Reply 1 of 7, by Towncivilian
I have a Sony Tape Tool v1.039 which I use with my Sony SDT-9000 SCSI DDS drive. Do you want to see if the utility will work with your drive as well?
abit BX-133 RAID, P3-S 1.4Ghz, 768MB PC133, Radeon 9000 PRO, AWE64, 2x40GB RAID1, Sony SDT-9000 & Connor CTD-8000 SCSI DDS2 DAT drives, Realtek 8169 1GB NIC, Adaptec DuoConnect AUA-3121, Win2k SP4
Depeche Mode Live Wiki
Reply 2 of 7, by Horun
There is no way to search for a firmware update without knowing the exact model # of your tape drive.
Reply 3 of 7, by BiggerJim
Horun wrote on 2023-05-12, 02:29:
Thanks for the reply. It's a Sony GY-2120WD
Reply 4 of 7, by BiggerJim
Towncivilian wrote on 2023-05-11, 21:39:
Thanks for the offer!
I've got that software too, but it doesn't have the ability to issue the "recover" command, unfortunately.
Reply 5 of 7, by PC Hoarder Patrol
BiggerJim wrote on 2023-05-11, 17:46:
This is my first post and not sure if this is the best place, but here goes... […]
This seems like the latest advisory firmware-wise, but thru their ServicesPLUS portal https://www.servicesplus.sel.sony.com/
Not had much luck tracking down scsitool.exe either 🙁
The attachment 00017075.PDF is no longer available
Reply 6 of 7, by Horun
So weird can find firmware for most older Sony DDS tape products (sdk, sdt, sdx, etc) and the LIB* series but not much on the GY series.
Here is a brochure: http://web.archive.org/web/20040720160736/htt … 20_finalrev.pdf
and some tools for NT and Win2k: http://web.archive.org/web/20030325194055if_/ … d=20070&d=10006
but they do not download...
Reply 7 of 7, by BiggerJim
Horun wrote on 2023-05-13, 01:00:
So weird can find firmware for most older Sony DDS tape products (sdk, sdt, sdx, etc) and the LIB* series but not much on the GY […]
Thanks, knowing the names (dtfw2k.exe and dtf2nt.exe) is one small step forward, but like you, can't find a sniff of them on the web. Even tried BitTorrent!
