First post, by soviet conscript
There seems to be a lot of upgrade paths for 8088 systems such as NEC V20, sprint overclock and all sorts of 8088 to 286+ accelerators like the Tiny Turbo.
Besides the swapping out for a NEC V30 for a modest speed bump are there any other options out there for upgrading an 8086? Most of the options that work for the 8088 are incompatible with 8086 systems such as the various accelerators.
Lastly , this is for entertainment and tinkering purposes, I know just getting a 286, 386 ect. Build would be cheaper and faster.
Reply 1 of 4, by Horun
The only PC upgrade I know of is NEC v30. There was an odd one saw long ago had a 80186 cpu on a card and a ribbon to a socket and think it worked for both 8088 and 8086 but was proprietary. An industrial application at Tektronix back in 80's and ran cp/m-86 or some such thing. My neighbor gave me a manual late 80's that I still have from (man date 1982) about the OS and usage. Sorry is all I can remember.
Reply 2 of 4, by Anonymous Coward
Horun wrote on 2023-05-14, 23:13:
There's the Microsoft Mach 10 with the 80186.
Not sure if those can upgrade 8086s, but it doesn't seem like it would be much of an upgrade.
The box claims it's compatible with a Compaq Portables, so that implies the answer is 'yes'.
Reply 3 of 4, by Horun
Hmm I thought the Mach 10 just upgraded a 8088 to 8086. Thanks. Guess my memory is getting bad 😀
added: Ohh no it is just a 8086, just watched Daves video. it has a soldered Siemens SAB8086-1 cpu. the socket is for Coprocessor. ok my memory is not quite as bad as thought 🤣
Reply 4 of 4, by Anonymous Coward
Maybe my memory is getting bad...but there definitely is an 80186 accelerator card.
https://forum.vcfed.org/index.php?threads/eve … -can-you.34569/
That one is pretty old an finicky. Not clear if it would work in an 8086, but probably best avoided anyway.
From what I read, the Sota 386Si might support 8086 though.
