Enable CON to handle DBCS characters
First post, by cyberwalker
The console (CON) is supposed to use Int 10H to display characters, but actually it bypassed for speed. So new Int 10H handler will not take effect on CON while hook on Int 16H will. This behavior will prevent applications from using their own 10H to display far east DBCS characters (Chinese/Korea/Japanese) at prompt.
This patch will restore compatibility by using real INT10 service instead of INT10 routines for CON outputting.
I have tested ET35(CHT) and XZL/TWAY(CHS) with this patch applied. Users running applicaitons use their own INT10H hook may be interested in this patch. I think compatibility is more important than speed.
I hope you will find this patch helpful.
    dev_con.h.diff.txt
    6.86 KiB
    18 downloads
    shell_misc_cpp.diff.txt
    928 Bytes
    22 downloads
    shell_misc.cpp
    15.12 KiB
    19 downloads
    dev_con.h
    11.66 KiB
    22 downloads
Reply 1 of 28, by Qbix
Rank DOSBox Author
DOSBox Author
It looks quite complex.
Can't you just call interrupt 29 ? (which in turns calls intt10 ?)
or does it lack some "intelligence" in dealing with certain characters/postioning elements.
Not sure though. maybe int29 should have the ansi parsing and not the con device. well details 😀
Water flows down the stream
Reply 2 of 28, by cyberwalker
Qbix wrote:
It looks quite complex. Can't you just call interrupt 29 ? (which in turns calls intt10 ?) […]
Maybe you are right. What I have done was to get it working by converting source directly.
Reply 4 of 28, by ykhwong
Why don't you make a patch by typing 'diff -urN A(previous) B(changed) < filename'?
It can be an easy way to check the changes or apply the patch.
    console.zip
    2.6 KiB
    20 downloads
Reply 5 of 28, by cyberwalker
I had thought a complete code was good for users not to use CVS tools and users could generate *.diff on their own. However *.diff files added.
Thank you.
Reply 6 of 28, by HunterZ
I think it's that a lot of people are maintaining their own CVS builds and would like to integrate your changes into theirs for experimental testing purposes. A patch makes this much easier to accomplish.
Reply 7 of 28, by cyberwalker
ykhwong, I tested your recent build and found no F11/F12 patch applied. The information on your english page requires correcting.
Reply 8 of 28, by ykhwong
I didn't add the keys ('/','*','+' and '-' on keypad) that will be recevied by DOS apps. But F11/F12 keys are not working? I thought that I properly applied it.
It was difficult for me to combine three files with a patch file below.
keyb.patch, qemukeyboard.cpp, and bios_keyboard.cpp
Check the attchment. Can you point out mistakes that I made?
    intlkey.diff
    19.66 KiB
    20 downloads
    experimental patch
Reply 9 of 28, by cyberwalker
ykhwong wrote:
I didn't add the keys ('/','*','+' and '-' on keypad) that will be recevied by DOS apps. But F11/F12 keys are not working? I tho […]
I have checked your diff file briefly. The file sdl_mapper.cpp was quite different than CVS's(and mine). I think new bugs have been brought in when you patched it before. You may want to debug your build.
Reply 11 of 28, by cyberwalker
ykhwong wrote:
Check this patch that moe modified. http://garni.ch/~jwalt/intlkey.diff
does the file sdl_mapper.cpp affect the operation of f11/f12 keys working in dos apps?
I think applying this patch should be ok. It seems keyboard.cpp patched with intlkey.diff in your last post changed the behavior of keyboard. I am not so sure. Debugging will tell the difference.
Reply 12 of 28, by ykhwong
I assume that some strings are repeated and max code was wrong in keyboard.cpp
I deleted three lines and changed code number 61 to 58.
Can you test dosbox.exe that I attached, cyberwalker? 😀
(I found that f11/f12 keys really do work in MdirIII app under my build)
Reply 13 of 28, by cyberwalker
ykhwong wrote:
I assume that some strings are repeated and max code was wrong in keyboard.cpp I deleted three lines and changed code number 61 […]
This build worked as expected. I think you have figured out what is wrong with keyboard.cpp.
I also found with Smart Updating enabled, the CPU usage decreased greatly when DOS is "Idle". Maybe Smart Updating will give DOSBOX a big advantage over VMware and VPC in running DOS applications, though it flickers displaying and forgets to update screen sometime.
Reply 14 of 28, by Qbix
Rank DOSBox Author
DOSBox Author
moved it to the patches section
It needs some discussion before I add it.
Added some comments on the sf page as well
http://sourceforge.net/tracker/index.php?func … 551&atid=467234
Reply 15 of 28, by knowen
hi all
i have a big problem about dos based prog. name is eta
it is working on win9x but we upgrade the system winxp pro sp2 and now eta is not working when i open the program i get ntvdm cpu error message and later program is closing
now i am working with dosbox v.70 it is working but i cant use turkish keywords (ş,ü,ö)
i searched the language file turkish.lng but i couldnt found
how i can resolve this problem ??
thanks a lot forums members
