Enable CON to handle DBCS characters
Reply 20 of 28, by MiniMax
Rank Moderator
Moderator
Download kpdos25x.zip from this site:
http://www.ibiblio.org/pub/micro/pc-stuff/fre … s/keyb/kblayout
Then extract the 3 SYS-files (KEYBOARD.SYS, KEYBRD2.SYS and KEYBRD3.SYS) and put them in the directory where you have installed DOSBox 0.70.
Start DOSBox and at the Z: prompt type:
Z:\>keyb tr
DOSBox should respond with
Keyboard layout tr loaded for codepage 857
_________________
Reply 27 of 28, by knowen
i am using dbglcons.cmd and i open the program with one click but i cant load keyb tr only one path allowed on the dbglcons.cms
when i open the dbglcons.cmd first run dosbox,later keyb tr and later program exe .
how can i
Reply 28 of 28, by MiniMax
Rank Moderator
Moderator
knowen - I don't remember if you can specify the keyboard layout in DBGL, but if that is impossible, you can create a little BAT-file with Notepad (e.g. StartETA.Bat) with the lines to set the keyboard and then start ETA. Something like
Keyb tr
ETA.Exe
Put the StartETA.Bat file in the directory (C:\eta ??) where you have the real ETA program, and tell DBGL to run the StartETA.Bat file instead of ETA.Exe.
_________________
