First post, by tomcattech
- Member
After banging my head on the wall playing with jumper settings everywhere I've finally got a p3 1.1 working on a Slot 1 using a MSI Socket 370 to Slot 1 converter.
The motherboard Asus P2B has an old school temp sensor and I want to get as close as I can to a real CPU temp without screwing up all the hard work I just did.
Any ideas on placement?
I either fix it or break it permanently... there is no try.
