First post, by i2lgames
- Newbie
Hello all, i recently got my hands on a Soyo SY-4SAW2 Rev WA3 and there was a bit of battery damage. I cleaned and replaced the battery with a cr2032, i removed the d2 diode to stop the charging. The thing is that it depletes the battery very fast! I install a new battery, it stores the settings correctly and after a couple of days, while the power cord is plugged in, the battery is empty and the settings reset if i power down the pc! I haven't changed the bios chip. I flashed a new bios with no problem whatsoever!
Any suggestions?
Thank you.
