First post, by CoffeeOne
I am currently testing a nice looking VLB video card.
1021.97 KiB
Display on booting:
1.75 MiB
No problem so far under DOS, in PCP 640x480 I get 12.1 which even exceeds the value from my Ark logic (11.1)
I am running Windows 98SE. There is a problem.
After Windows searches for a driver itsself, it installs a driver called "S3".
After rebooting I saw, that the screen was switched to 640x480 at 85Hz, my Eizo 19" TFT monitor displayed "out of spec", but still displaying the picture fine.
Afterwards the mouse pointer got stuck.
So I thought the 85Hz thing is the problem. I then found some Spea tools and XREFRESH for DOS.
So before starting windows, XREFRESH gets called:
1.65 MiB
Unfortunately that did not solve something. After booting windows the screen refresh rate is 75Hz (no more warning from the monitor), but windows crashes hard with the S3 driver.
First there is a pink mouse pointer and then everything gets stuck.
1.71 MiB
1015.19 KiB
So I tried different drivers (that come with Windows 98SE), whatever I choose, it is always referring to
C:\WINDOWS\INF\DX3.INF Date 1999 5 5 => always the same effect. crash.
I found Elsa driver for Windows 95 (date 1995) similar problem, Windows 98SE is crashing.
However with the built-in "Standard VGA" or "Super-VGA", windows boots and loads normally, but with that driver there is only 640x480 with 16 colours possible.
I don't think the card is broken, because (mentioned above) for example the PCP benchmark from Phil's suite runs fine in 640x480, 256 colours and 75Hz.
Reply 1 of 7, by zami555
Some time ago there was a similar topic, but with ATI VLB card, where similar issues were found under Win98SE. In that case all was fine when tested with Win95. Have you tried to test this setup under Win 95?
Link to topic with ATI VLB and Win98SE: Hangup during booting Windows 98SE with ATI Mach 64 VLB 4MB. Looking for proper ATI Mach 64 VLB driver for Windows 98 SE
Reply 2 of 7, by Horun
Found this note in the Elsa 1000 W95 driver: "WINNER 1000AVI-VL
This board works only with up to 64MB main memory. The S3 chips 868/968 need 64MB physical address space and the VL-bus can only access 128 MB.
For this board use the following entries in the section [Hardware] in your ELSA.INI file:
VRAM-Base=0x4000000
VRAM-Size=0x4000000"
How much ram do you have ? If on a 486 doubt you have more than 64Mb....
Reply 3 of 7, by CoffeeOne
zami555 wrote on 2023-05-20, 22:05:
Good catch!
Very funny, I was even participating in this thread, 🤣.
No I don't have tested with Win95, I want to stick to Win98SE, even if it is overkill for a 486 machine.
I am using the well known Asus VL/I-486SV2GX4 Rev.2.0 and an Elsa S3 with Edo RAM, but the situation is similar to the linked post:
I use 4 times 16MB FPM, so 64MB in total.
The "solution" in this thread was to downgrade to 3 times 16MB, I will definitely try that.
Also I found this thing in the Elsa Win95 driver: They wrote, that you can have maximum 64MB RAM, because of the 64MB area of the linear frame buffer.
So I should be fine.
Also there was written, that you must use the Elsa windows driver, otherwise you can have problems with the mouse pointer, somehow that looks like the problem I am facing.
Reply 4 of 7, by CoffeeOne
Horun wrote on 2023-05-21, 00:03:
Found this note in the Elsa 1000 W95 driver: "WINNER 1000AVI-VL This board works only with up to 64MB main memory. The S3 chips […]
VRAM-Base=0x4000000
Exactly 64MB, I found that note, too. See my previous post.
A bit offtopic here: I have one 486 machine with 112MB RAM (3 times 32MB, 1 time 8MB and 8MB onboard), it is the Compaq 486 Prosignia Server. It is nice to max out old boards, 128MB is maximum for the Compaq (then the onboard 8MB get disabled).
Reply 5 of 7, by CoffeeOne
I solved the problem.
I thought the system was stable, because I ran some dos benchmarks and Windows 98SE was running, but it was not.
So I removed one 16 mb module, no change (crash with Windows 98 SE s3 video driver), removed a second one, keeping only 32MB of RAM => same.
Then I thought, let's do a last try. I went to BIOS and set all settings to the slowest setting. And I was able to start Windows 98SE with the s3 driver.
I put back in all the RAM so 64MB, still working.
I actually found out easily what exact setting was the problem:
Local Bus Transparent. I had to change it to Synchronize, everything else can stay on best values.
Great success.
I did then a stability test, I ran a rendering with Lightwave 3D, no problems.
I will now start playing with the mclk utility ...
Reply 6 of 7, by Horun
CoffeeOne wrote on 2023-05-21, 17:39:
I solved the problem. I thought the system was stable, because I ran some dos benchmarks and Windows 98SE was running, but it wa […]
Great success.
Great ! so you are using the "ELSA WINNER Windows 95 Driver Disk, ver 4.03.2115" for WINNER 1000AVI ?? I want to make a note in my S3 stuff 😀
Reply 7 of 7, by CoffeeOne
Horun wrote on 2023-05-21, 18:30:
Great success.
No. Built-in Driver from Windows 98SE "S3", dated 5-5-1999. So a lot newer than the Elsa driver.
It seems to fully detect the hardware correctly.
