First post, by wbahnassi
- Oldbie
Hi, as I was browsing the SB AWE32 books, I found mention of loading the CM-32L drum kit. I got excited with the idea and wanted to try it with Might & Magic 3, which uses CM-32L for additional sound effects you miss on the MT-32. However, for the life of me I can't seem to figure out how to load this drumkit. I haven't found any further explanation in the books.. so I'm asking for help here.
I guess you do this via the AWE 32 Control program, where you can choose MT-32 or GS or General Midi for the synth. The book gives an example to replace the program in MIDI channel 10 to 26 for TR 808 drum kit. So I assume this should be similar for the CM32-L. Basically, replace program 10 with 128. But how to do this? Any idea?
I've attached photos of the relevant AWE32 book pages plus some screen shots of AWE32 Control program in case this helps in some way.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, TSeng ET3000, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
