First post, by GunKneeNeon
I have a Trident TVGA 9000c ISA video card and I use an AOC MW19N-AA 932Sw LCD monitor. My 9000c has 512kb memory, it support the resolution of 800x600 with 256 color mode. But my LCD refuse to accept the output from my video card. When set the resolution in windows, the LCD became black screen with error "Input not supported". I have another PCI video card, which is a S3Trio64V+. The LCD displays in 800x600 256 color mode with the card perfectly fine. So what would be the issue the 9000c has? Is it the refresh rate 9000c output that is non-standard? I have no way of finding the output refresh rate when the screen is black. However, when I set the resolution to 640x480 256 color, my LCD works in 60hz.
This is my current jumper settings:
1.78 MiB
My current Jumper settings
Constantly looking for the driver for Acer Magic v1 MPEG decoding card.
Reply 1 of 48, by Tiido
This card produces a 56Hz output in 800x600 from what I remember, LCDs tend to be quite picky with what they'll display and many ISA cards output timings many LCDs are not particularly fond of, especially low end things like these Tridents.
Reply 2 of 48, by GunKneeNeon
Tiido wrote on 2023-05-28, 01:14:
Is there a way to force the card outputs a certain refresh rate? I found an article about this, but it didn't work. Beside this, I really don't understand the logic behind it. When the card output 640x480 256 color to the LCD, the LCD detects that the refresh rate is exactly 59hz. What in the earth is the reason that it can output 59hz when in 640x480 but can not do the same in 800x600 mode. It's only 3hz lower than 59hz, not a big difference. I cannot think of it being unable to produce that 3hz more frequencies to make the LCD happy.
Reply 3 of 48, by Grzyb
It's possible the card is configured for 800x600 with interlace.
Try SVM.EXE - AFAIR there are options to test various refresh rates and interlace settings.
Also, are you sure that card has 512 KB of RAM?
It looks weird...
4 x 41256 = 128 KB
I don't know about those IBM chips, but they may be 41256 equivalents, so another 128 KB, and that would be 256 KB total - but that's not enough for 640x480x256...
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 4 of 48, by jmarsh
GunKneeNeon wrote on 2023-05-28, 12:05:
The LCD info is probably rounding down, 640x480 is usually 59.94fps which is practically 60fps while 56fps is significantly different.
Reply 5 of 48, by GunKneeNeon
Grzyb wrote on 2023-05-28, 13:31:
I cannot find the jumper settings specifically for my card anywhere, but here is a topic for 8900D which has a very similar jumper layout to mine. The jumpers settings in the manual says J7(open) is for non-interlaced monitors. I had my J7 open as well, see the picture I posted before.
Input not supported when select 800x600-256 NI(the three 800x600-256 modes have the same result).
372.89 KiB
Also, are you sure that card has 512 KB of RAM? It looks weird... 4 x 41256 = 128 KB I don't know about those IBM chips, but the […]
It looks weird...
4 x 41256 = 128 KB
The test result of the Tellset utility:
283.91 KiB
The BIOS info screen when booting up:
15.34 KiB
Reply 6 of 48, by Grzyb
OK, I'm inclined to believe those IBM 90x0711 chips are 256K x 3-bit.
Does 800x600 16-color work with your monitor?
And how about 1024x768 ?
Reply 7 of 48, by GunKneeNeon
Grzyb wrote on 2023-05-28, 16:29:
Yes, in SVM they both worked. Though 1024x768-16 showed a low quality image with vertical green lines in it.
In Windows 95, again the 800x600-16 mode worked, however when selecting 1024x768, the color palette option automatically turned into 256-color, which obviously wouldn't work. This was with the Windows' stock Trident Super VGA driver. With Trident Chip for ISA/VSL V1.0 driver, there was only 256-color option under color palette.
Reply 8 of 48, by Grzyb
TVGA9000C supports two non-interlaced 800x600 256-color modes:
85.34 KiB
Not sure how to select them... TVGACRTC.EXE may be the proper tool.
Reply 9 of 48, by GunKneeNeon
Grzyb wrote on 2023-05-28, 17:09:
Ahh.... We've made a progress here. See my picture of the TVGACRTC utility. The frequencies from 75.0-98.0MHz are supported, which correspond the refresh rates from 58.41-76.32Hz respectively. All divided by 1.
599.47 KiB
However, the images are not correct like this one.
607.61 KiB
Reply 11 of 48, by GunKneeNeon
jmarsh wrote on 2023-05-28, 19:07:
How do you know those frequencies are supported for that board? They are rather high for an old ISA card.
Well, I'm not saying the board support that. I'm saying such refresh rates are supported by my LCD. Only rates in this scope output images to my monitor.
Reply 13 of 48, by GunKneeNeon
jmarsh wrote on 2023-05-28, 19:27:
None of the frequencies in the left column produce an image at all on the LCD?
Yes, any refresh rate out of 58.41-76.32Hz generates an Input not supported error and a blank screen.
Reply 14 of 48, by Grzyb
The datasheet can be downloaded from http://www.vgamuseum.info/index.php/component … ident-tvga9000c
For 800x600x256 NI, the highest pixel clock listed is 50.3 MHz...
Reply 15 of 48, by GunKneeNeon
Grzyb wrote on 2023-05-28, 19:37:
50.3MHz only corresponds to 39.21Hz refresh rate. Does that mean what supported by the VGA is not supported by the LCD and vice versa?
I've tested the frequency range with 800x600-16 mode, the board can produce acceptable image when set to 98MHz Divided by 2, result in 76.56Hz fresh rate. Does that mean the board can work at 98Mhz(at least temporarily)?
Reply 16 of 48, by Grzyb
GunKneeNeon wrote on 2023-05-28, 19:48:
50.3MHz only corresponds to 39.21Hz. Does that mean what supported by the VGA is not supported by the LCD and vice versa?
I'm lost...
According to the datasheet, 50.3 MHz pixel clock corresponds to 72 Hz VSYNC.
Something's wrong... misconfigured jumpers? Mismatched software?
Reply 17 of 48, by GunKneeNeon
Grzyb wrote on 2023-05-28, 20:01:
I'm lost... According to the datasheet, 50.3 MHz pixel clock corresponds to 72 Hz VSYNC. […]
I'm lost...
I'm also confused that the default frequency selected by TVGACRTC in 800x600-256 mode is 72.0MHz, which corresponds to 56.07Hz refresh rate. That's not supported by my LCD. However, with 36.0Mhz selected in 800x600-16 mode which corresponds to 56.25Hz refresh rate, it works! WTF!
As for the jumper configuration, I never find a doc specifically for TVGA9000C. Well, not really, here is the doc about 9000C, but it seems not for this card. Because the card doesn't have jp3-jp5.
151.51 KiB
94.06 KiB
117.65 KiB
71.92 KiB
PS: Sorry to post so many screenshots, the site doesn't allow me to copy the text. The whole doc is here. The TVGA9000 part is more reasonably.
Reply 19 of 48, by Grzyb
There was this problem with earlier Tridents:
The Trident 8800 chips have a problem with 256 color modes, as they always double
the pixels output in 256 color mode. Thus a 640x400 256 color mode (5Ch) actually
uses a 1280x400 frame, requiring at least a multi sync monitor.
This problem is fixed on the 8900.
With 16 colors, 36 MHz pixel clock = 56 Hz refresh rate...
With 256 colors, a pixel actually needs 2 clock cycles, so the same refresh rate requires 72 MHz pixel clock...
That would make perfect sense, but 8800 and 9000C are completely different chips, the latter is newer and shouldn't have that limitation.
Again, must be something wrong with configuration and/or software, something that makes it behave like the 8800.
