First post, by Kordanor
I got a Monster 2 card and a Socket 7 board which has the CPU placed in a way that's impossible to use that monster card.
So before I buy yet again a new board, I was wondering if it would be possible to use a PCI extention cable instead.
Does anyone have any experience with this? I only have a 90 degree "riser" card for now, and that didnt seem to work (it had capacitors on it). Not sure if the riser card is broken, the Voodoo Card is broken (will test that on a different board when I find the time) or if the combination just wont work.
In any case what I would need is a "flexible" cable to basically have the PCI card occupy pretty much an ISA slot instead.
Maybe something like this?
https://garmade.com/products/pci-32bit-riser- … ble-length-15cm
Anyone got any experience /advice on this?
