CGA Cursor Hiding
First post, by GloriousCow
I'm a little confused by the behavior of the CGA cursor.
I was informed by a BIOS developer that I'm showing a single pixel tall cursor at the top of the screen in my emulator where the cursor shouldn't be visible.
This is also present in the menu of CGA_COMP where the cursor should be hidden. This is a condition where CursorStartLine = CursorEndLine = 0 and the cursor attribute bits are 00.
If this would hide the cursor, great. But the issue is my own test program shows that it does not:
The attachment cursor_small.JPG is no longer available
This code just does
mov ax, 000Ah ; Set CursorStartLine to 0
out dx, ax
mov ax, 000Bh ; Set CursorEndLine to 0
out dx, ax
Is there some other condition necessary to hide the cursor in this case?
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 2 of 2, by GloriousCow
sigh. I had a stupid bug in masking off the attribute bits, so I didn't see both the BIOS and CGA_COMP were in fact setting bits 5&6 to 01.
No use in having debug displays if they feed you bad information...
