First post, by Duffman
Hi,
I was trying to install DirectX 9 on my WeeCee, but DirectX setup says the CPU is incompatible with it and won't let me install.
I think it's because DirectX setup doesn't know what a Vortex86DX CPU is.
So I would like to modify dsetup32.dll to skip the CPU check, but every time I've tried that I've broken the file.
Can anyone more skilled at hex editing do this modification for me?
    dsetup32.zip
    174.16 KiB
    42 downloads
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 1 of 7, by Duffman
It says
Processor Type Unsupported by DirectX.
and that I need a Pentium or K6 class processor or higher.
So, any ideas on how to bypass this check?
edit: screenshot
1.25 MiB
CPU: Ryzen 9 5950X
Reply 2 of 7, by bakemono
I suspect your problem is around this area. What does Vortex86DX return for GetSystemInfo?
    16.48 KiB
again another retro game on itch: https://90soft90.itch.io/shmup-salad
Reply 3 of 7, by Duffman
@bakemono
I'm not sure, how do I check for what it's returning?
CPU: Ryzen 9 5950X
Reply 4 of 7, by Duffman
@bakemono
Modded the function and got DX9 installed, thanks.
CPU: Ryzen 9 5950X
Reply 5 of 7, by Towncivilian
Would you mind posting the hex patch in case someone needs it in the future?
abit BX-133 RAID, P3-S 1.4Ghz, 768MB PC133, GeForce FX5200, SB16 ISA, 2x40GB RAID1, Sony SDT-9000 & Connor CTD-8000 SCSI DDS2 DAT drives, 3COM 10/100 NIC, Win2k SP4
Depeche Mode Live Wiki
Reply 6 of 7, by Horun
Duffman wrote on 2023-06-03, 10:58:
Great ! please post the patched file.
Reply 7 of 7, by Duffman
Here you go.
CPU: Ryzen 9 5950X
