First post, by Burrito78
Hi,
i have sound distortion during speech with Worms Revolution (CD) using SVN r4482 (Dominus macOS build).
The issue doesn't happen using 0.74-3-3.
Config is default config for both and hardware is Apple M2 mini (2023) with macOS Ventura (latest).
Sound recordings attached.
Sound Blaster: From best to worst
Member of DOSBox Staging
Reply 1 of 3, by Burrito78
Bisecting in DOSBox's subversion repository:
r4112 was the last SVN commits where Worms voices play clean.
r4113 fixed SVN bug #482, but introduces a repeating pitter-patter in Worms.
r4175 solves the pitter-patter in Worms, but introduces a warble in the voices.
Reply 2 of 3, by elszgensa
> Worms Revolution
I'm guessing that should be "Reinforcements"?
