ASUS P4P800 disaster
First post, by BreakPoint
Over last few years I've tested hundreds (if not thousands) boards which i saved from gold recovery. And there one thing I cant understand.
Based on my statistics ASUS boards are pretty reliable. But ASUS socket 478 boards are complete disaster. 80% to 90% dead rate on a boards with no visual damages.
Any ideas why Asus socket 478 boards dying like flys?
My CPU collection - Looking for hardware in Ukraine - Ukraine vintage PC forum
Reply 1 of 45, by The Serpent Rider
ICH5 south bridge and USB ESD protection or the lack of thereof, to be precise. Well-known issue. ASUS and several other manufacturers supposedly fixed that in new revisions.
Reply 3 of 45, by SSTV2
I have this general observation about s478 motherboards, ASUS or any other M/B brand - boards with a BGA socket 478, that in the past used a stock intel cooler with a death-clamping force, either failed or are about to fail soon due to cracking BGA joints, this fault can be simply diagnosed by turning M/B over (with a heatsink on) and pushing on the CPU area with enough force to deform PCB back a bit.
Reply 5 of 45, by SETBLASTER
SSTV2 wrote on 2023-06-10, 17:10:
thats interesting. and they even had a backplate on the motherboard
cooler alternatives are also bad , since they need the stock plastic retention, like the zalman cooolers
Reply 6 of 45, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Zerthimon wrote on 2023-06-10, 15:50:
I would refrain from using words like holocaust, Hiroshima, etc. in public forums. May hurt many people's feelings.
Agreed and thus I changed the topic
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 45, by The Serpent Rider
Socket 478 is Pin Grid Array. Typical PCB deformation from cooler won't affect it.
Reply 8 of 45, by BreakPoint
Here is P4P800 socket soldering. Does not look like BGA to me.
    256.91 KiB
Reply 10 of 45, by The Serpent Rider
I have yet to see such issue on a massive scale, because BGA under these pins are not physically connected to CPU and tension should be minimal anyway. ASUS also had backplate on premium S478. You certainly can damage them by brute forcing CPU out of a socket with closed latch though.
Anecdotally, the only board I have with such problems is Socket 939.
Reply 11 of 45, by Brawndo
Interesting. I have at least one P4P800 and as far as I recall it's working fine. I believe I also have another ASUS 478 board which also works fine, don't remember the model. I don't do anything with P4 systems so I'm probably going to sell all that.
Reply 12 of 45, by Tetrium
The Serpent Rider wrote on 2023-06-10, 15:25:
You mean they fixed it with new motherboard revs or fixed it by using new ICH5 revs?
Which southbridges were affected by this anyway?
My retro rigs (old topic)
Report spammers here!
Reply 13 of 45, by The Serpent Rider
It's assumed that both Intel and motherboard manufacturers had collective fudge up.
You mean revision number? Not sure, but every working ICH5R board in my possession (including ASUS P4C800-E Revision 2.0) has SL742. Asrock LGA775 boards have SL7YC (ICH5).
Reply 14 of 45, by Roman555
The Serpent Rider wrote on 2023-06-12, 16:46:
It's rather not a revision but a serial number.
First symbols of serial numbers of Intel ICH5 faulty chips:
32,33,34,40,41,42,43,44,45,46,47,48,49,4А,4В,4С
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 15 of 45, by Socket3
Karbist wrote on 2023-06-10, 18:53:
p4p800 has a bios corruption issue and also the 2 mosfets on 1.5v rail near the north bridge chipset get very hot and eventually die.
^this. I've been able to fix P4P800 boards by either replacing the eeprom (stock one was damaged and re-flashing did nothing) or replacing the VRMs. I've managed to repair 6-7 boards so far.
I've never heard of this issue. Maybe it's because I don't own any early revision boards?
Reply 16 of 45, by The Serpent Rider
Roman555 wrote on 2023-06-12, 19:41:
Well, in that case both of my boards are faulty as well: F32 and F40.
Reply 18 of 45, by Tetrium
It's rather not a revision but a serial number. […]
Thanks! This is useful information 🙂
Reply 19 of 45, by Roman555
Tetrium wrote on 2023-06-13, 11:07:
Welcome! I got this information on a ixbt forum. But I haven't checked it personally.
