First post, by EnergyStar
It happens quite rarely that the motherboard will boot. At first, the X1 quartz sizzled even when the power supply was unplugged and the BIOS backup battery was charged. When I slightly bent the laminate of the motherboard in the upper left corner to the center, the sizzle stopped and the board started up. So I corrected any solder in that area. I desoldered and checked the transistors adjacent to the X1 quartz. I replaced all tantalum and ceramic capacitors (except coin). I checked all the elements for a short circuit, checked any suspicious paths that I could see. I was programming the BIOS. I replaced the BIOS backup battery. I checked if there is power to the chips, to the ISA and RAM slots. The error code stops at 13 after a while it switches to 00.
The processor, as you can see in one of the photos, had several legs skewed. I bent them so that they did not touch each other and checked if they all have a connection to the pads.
I bought a quartz resonator tester. I wanted to test the X1 quartz with it to find out what value it has, but there is no reading. I also tried soldering a similar looking quartz from another motherboard from a similar period of time but it didn't help.
Is it a short circuit between the PCB layers or something else could help?
