First post, by alext0077
Trying to create a "better" version of what I remember growing up with.
- Original machine as bought on eBay was a Wyse 2112 - 12.5 MHz, one wait state. The one I had growing up was branded as an Amdek System/286 which must have been the "retail" version of this computer as it was purchased at a ComputerLand store. This specific computer was rebadged as an OCLC machine - a library reference system popular in the 80s and 90s; Assumed in some library for most of it's life - it was very clean inside.
- Swapped the motherboard card with one from a Wyse 2214 - also 12.5 MHz, zero wait state - boots successfully and works in the 2112's backplane - indeed this type of upgrade path was a selling point of the system.
- Currently has the original 40MB (and still working) ST-251 MFM drive, Spinrite reports zero additional bad sectors over what was documented on the drive label. Added a simple Cirrus Logic VGA card, swapped the 5.25 for a 3.5" drive, and a Gotek floppy emulator with the HxC firmware
- A bad keyboard controller chip on the 2214 board was causing endless headache with "Gate A20 Uncontrollable" errors when HIMEM.SYS was loading. Swapped it with the one from the 2112 board and the error went away.
- Three cheers to the person that uploaded the setup utility for this series of Wyse systems to archive dot org
- Refurbished the LCD display; after decades the original electroluminscent backlight had failed long ago. Replaced with a new 16 character LED backlit one - some small wiring changes to get the backlight working.
Problems to figure out / to-do list:
- Tried adding an Adaptec 1542B SCSI controller. Even with no other peripherals except the VGA card int he machine - it hangs when the SCSI BIOS are initialized. Tried different addresses, settings, IRQs - same effect.
- Added a generic NE2000 ethernet card (mostly for the Boot PROM slot so I can add a XTtoIDE universal BIOS) - but can't get it working quite right with my modern wired network.
- Will likely just swap the spinning hard drive for an IDE controller and small SSD
