First post, by cloverskull
Hey friends,
I have a PODP5V which appears to run just fine at 100mhz on my motherboard. So...great! I also have two VLB cards - one for I/O (serial, parallel, IDE, floppy) and one for VGA. They also, as far as I can tell, appear to work fine at 40mhz.
So, my question is, is it safe to run two VLB cards at 40mhz for extended periods? How would unsafe behavior surface, i.e. graphical artifacts, or full system freezes?
There's the 0WS / 1WS jumper on my mobo. How safe would it be to try 0WS? There's also a setting in BIOS which I can play with. I'm just nervous about creating some sort of corruption on the drive or something of that nature. Is it safe to experiment here and try to eek out more performance?
Thanks!
