Mouse behaving strang
First post, by Ithkul(waitin register)
Here's an odd issue:
Im trying to get dosbox working at work with the two games ; Arena and Master of Magic.
I made them both run smoothly (no sound, so i disable all sound support in conf). But the mouse moves strangly. I tried two diffrent mouse, both have the same problem. both act the same way in both of the games
the mouse follows my movement pattern, but at a delayed rate 4-6 sec. but the really odd thing is that if i stop moving the mouse it stops instantly. then if i move the mouse the other way it continous the way i was moving it the first time(before i stopped moving it). its like it has memorized my movement. so it has to move out those movements before it can make new movements.
ie. i try to click a button. but the mouse loves to be offscreen. i slowly move it towards the button, but its moving past it or above it. then when i try to stop and move it in an other direction it continous the way it was going. very annoing. with practis i been able to "aim" buttons. 🤣
any idea what can be done? 😢
Reply 1 of 10, by ithkul
my account up and running. please notify me if u know the issue and have a solution at hand.
Reply 2 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
how fast is your cpu
and how many cpu cycles do you use ?
Water flows down the stream
Reply 3 of 10, by ithkul
tried cycles from 1000-10000. tried frame skip from 0-10 on diffrent cycles. tried with and without sound. with and without CD-rom. more memory and less memory. etc etc
will check cpu info next time i boot it. think im behind some major firewall and admin-user-limitations.
Reply 4 of 10, by ithkul
CPU : P4 - 2.6GHz
128 MB DDR ram 400MHz
as i mentioned the game runs smoothly. the mouse f***s up.
Reply 5 of 10, by eL_PuSHeR
Hey, mate, just 128MB for a P4 2.6? - Heh
You would notice a hell of a difference going from 128MB to 512/1GB (specially for Windows XP).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 6 of 10, by ithkul
did u know that is most cases 256 Mb ram 333 Mhz preforms less than 128 Mb ram 400 Mhz?
anyway its the office computer at work. only used for MS office programs etc.
just beaten MoM on easy dif with this mouse issue. was a nightmare. 🤣 🤣
Reply 7 of 10, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
I find this very hard to believe... I have heard the opposite (not much point in having quicker RAM). Having 2 times more RAM is far better for WXP than any increase in memory speed...
Anyway: using 128MB for WXP is crazy... Ok, I guess it works (well I remember W95 worked on 8 MB), but well if you had 1 GHz processor and 256 MB memory, it would be better for WXP ...
Mirek
Reply 8 of 10, by HunterZ
I've never noticed a significant change in performance as a result of changing memory clock speed, but I admit I haven't experimented much. I do find it extremely hard to believe that a 100% increase in capacity brings less performance than a 20% increase in speed, especially when the difference between any amounts of RAM up to 1GB (1024MB) is quite noticable.
Reply 9 of 10, by `Moe`
Which version of dosbox do you use?
Reply 10 of 10, by Guest
using dosbox v.0.63 ofcouse.
note that i might be wrong about the memory thing. but thats quite off topic. I dont think ram is the issue sins the game itself runs smoothly. damn computer. have to say it again. this is not my personal computer. so upgrading it is out of the question.
still not been able to make the mouse work... 😢
