Full screen too big
First post, by Guest
When ever I put the Dos Box in full screen mode it stretchs the image almost 3 inches to tall for my moniter. I've tried it on every display setting in the .conf file. If anyone know's anything that could help please speak up.
Reply 1 of 6, by HunterZ
Adjust the vertical size controls on the front of your monitor? Set a different video mode for full-screen?
Reply 2 of 6, by `Moe`
If all else fails, look at the "fullfixed" and "fullresolution" options in dosbox.conf
Reply 3 of 6, by vonn
I've changed all of the Dos Box .conf resolution settings and it still won't work, and I've already adjusted my monitor, and it has the same effect.
Reply 4 of 6, by eL_PuSHeR
Then you should tried tinkering with output= parameter if you haven't already done so.
Start, by using output=surface, but you should test all available modes, i.e, surface, overlay, opengl, etc...
PS - Are you sure you are properly selecting the best resolution?
Could you post here some excerpt from your DOSBOX.CONF?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 6, by piercedgeek
I was having similar issues as above, this worked for me:
fullfixed=true
fullresolution=640x480
now only have about 1 inch of blank space on the left side, which is MUCH better than having most of the screen out of view.
If I use 800x600 for fullresolution, it's more centered, but has maybe 1 or 2 inches of black around the sides
Reply 6 of 6, by eL_PuSHeR
Check your scaler= setting too.
Intel i7 5960X
8 GB DDR4 (2100)
