Red Alert
First post, by mystery666
Ok so i have downloaded Red alert uesing BT and i have been and unzipped all the files ect. So unlike most people who have been trying to run red alert i am not running it from a CD but i have no idea how to get this to install.
I have mounted (or so i think) my c drive and the folors containg red alert but no matter what commands i try i cann't seem to get the setup started. I can get the setup started in command prompt, but as we know that wont give me a DOS shell! 😵
So i would appriciated if someone could run me through some lines of DOS code.
The main directory where red alert is
C:\RED ALERT ALL\
and each CD has its own directory too, so its
C:\RED ALERT ALL\RED ALERT CD 1
C:\RED ALERT ALL\ RED ALERT CD 2
all of the setup files are loacted within the directories, but as i said above i cant get them to run. Any help will be appriciated!
Reply 1 of 6, by mystery666
Ok, i mangaed to mount it correctly!
as mount c "c:\red alert all\red alert cd 2\ setup"
that got me mounted i then type setup.exe
and i then get the error cann't read setup.mxi from cd-rom.
Reply 2 of 6, by eL_PuSHeR
It should be easier to do...
- Copy all installation files to C:\redinst
- mount c c:\
- mount d c:\redinst\ -t cdrom -usecd 0
INSTALL
PS - I remind you that using BT to download copyrighted material is ILLEGAL.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 6, by HunterZ
Long filenames (anything longer than 8 letter/number characters, a period, and 3 more letter/number characters) and filenames with spaces are not supported under real DOS and thus not in DOSBox.
Reply 4 of 6, by DosFreak
Here I'll say it before someone else comes in. 😁
You can mount directories longer than 8.3 filenames in DosBox but it's not recommended. It sort of implies to the unknowledgeable user that DosBox does support Long File Names....when it doesn't (only for mounting!). It's best just to use 8.3 character filenames in all cases.
So no "C:\This is my red alert directory isn't it grand"
it should be
"C:\RedAlert"
Make your games work offline
Reply 5 of 6, by mystery666
Well i installed it!
Although the game doesnt run, i mount the drive it is installed and the directory and type RA like i am ment to, however the game doesnt start!
Well i lie, it kind of starts it loads the text that says, DOS red alert ect. and then it seems as like it attempts to load it. But the screen just stays black.
