Windows 98 antivirus
First post, by fractal5
I don't need to be educated that Windows 98 is insecure and always will be.
I just would like a suggestion for what antivirus is recommended on Windows 98, these days. By these days, I mean, something that comes with a nice offline database that doesn't try to seek out definitions or require online functionality that is long deprecated. The intended use case is that instead of moving stuff to a modern computer, checking it with virustotal or clamav -- I'd like to have some minimum sanity check of sorts on the Windows 98 computer itself. I might run various utilities on an old CDR.
While this isn't a critical system in any way, I'd still rather not have to mess with unwanted side effects from malware. This seems like a low cost effort to mitigate that, a little bit.
Reply 1 of 9, by dormcat
IIRC Avast 4.8.1368 (released in November 2009) was the last Avast officially supported for Win9x.
Reply 3 of 9, by fractal5
dormcat wrote on 2023-06-30, 23:00:
Thanks for the suggestion, this one unfortunately didn't work, "not enough thread space" or something like that.
Reply 4 of 9, by dormcat
fractal5 wrote on 2023-06-30, 23:52:
"Not enough space for thread data"? How much RAM do you have?
Reply 5 of 9, by jakethompson1
F-Prot was another that supported DOS, and then Windows 9x, up until the bitter end. I believe until around 2007 or so. But they are out of business entirely now, I think.
Reply 7 of 9, by fractal5
This is the error, if anyone is curious, happens with all the oldest versions I could find on oldversion.com (including the very oldest): "r6016 not enough space for thread data windows 98"
Reply 8 of 9, by shevalier
Backup?
It's faster to recover than to defend.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 9 of 9, by fractal5
shevalier wrote on 2023-07-01, 11:43:
Backup?
I have backup.
The use cases are: Install Windows 98, install some games, utilities and programs, some of which are shareware and freeware, from various CDRs and miscellaneous places, e.g. I might find one utility online, I might find another on an old CDR. I just want to see them again, for nostalgic reasons.
If I don't have any antivirus, I might get some old malware that is easily identifiable through signatures and the benefit of this, over reinstalling from backup, is that:
* I don't need to spend time on reinstalling.
* I don't need to reinstall, without knowing what caused the issue in the first place.
And yes, there's the downside, that:
* The antivirus might not identify it at all.
* I have to spend time on finding a working antivirus.
