First post, by nhattu1986
Hi,
I recently acquire the HP Kayak visualize x550 (which i believe that it is Kayak XW badgered)
The machine is able to power up, the little LCD panel show the smiley but there nothing else.
Then i removed all the card, put in a POST card, the post card show some activity then the post is stopped at code E7, there are also some faint (very faint) beep noise from the speaker. Sometime, the LCD screen show BIOS error, most of the time, it happy.
When i checked with the HP document, E7 is the part when bootblock tried to jump start the BIOS.
Thinking that the BIOS may having problem, i tried to flip the sw10 (BIOS recovery) to ON then reboot, the post code now jump to EC and stop.
No matter what ram i put in, it always stop at EC (SW10 on) or E7 (SW10 off).
So what should i checked next?
Now i'm thinking of remove the two bios chip and manually flash the bios onto them. But that is for the future.
The board come with one P3-Xeon 550 processor installed, one termination card on second slot, 2 VRM installed in VRM slot 1 and 2.
mainboard out of the case, with E7 from post card.
when i flip the SW10 to ON.
