First post, by boggsman
This is my system that I use for playing Windows XP era games, and a lot of GOG games. I built the machine in the early 2000s but I have upgraded things here and there.
Gigabyte GA-7VT600 KT600 motherboard
AMD Athlon XP 3200+
Akasa Silver Mountain 2 cpu cooler
3GB OCZ Platinum DDR400 2-2-2
Sapphire ATI Radeon X1950 Pro 512MB AGP
SB Audigy
Reply 1 of 14, by boggsman
A couple more photos
Reply 2 of 14, by JayAlien
Nice build, I have the same motherboard and CPU combo in one of my PCs. Do you find you’re CPU limited with the GPU you’re using?
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 3 of 14, by nd22
Very nice system! Does the motherboard has the P4 connector or do you use a period correct PSU?
What do you use for storage: HDD or something more modern?
Reply 4 of 14, by gerry
the ultimate XP+ i believe, very cool (well, actually runs pretty hot!). I have an XP3200+ too, no home for it yet - what i dont have is a graphics card like yours, that's very nice and means all kinds of mid 2000's game will play well on it
Reply 5 of 14, by boggsman
Thanks guys, I really appreciate the kind words ❤️
JayAlien wrote on 2023-07-03, 03:37:
Some games it seem like I am, but I overclocked the graphics card for a while and it picked up FPS in some games, so I guess it depends on the game. I love the Athlon XP and I have a lot of nostalgia around it so it doesn't bother me. It's a solid board. I had mine recapped a while back tho as the caps were bulging.
nd22 wrote on 2023-07-03, 08:44:
The motherboard does not have a P4 connector. I use a period correct PSU. I am currently using a 500BG 7200rpm hard drive with a SATA to IDE adapter, but I have been thinking about moving to a SATA SSD. The machine feels pretty fast in Win XP with the hard drive so that's why I haven't made the jump yet. Way back in the day I had a Ultra160 SCSI adapter with a 15K SCSI drive but it was loud and kind of overkill.
gerry wrote on 2023-07-03, 09:57:
It actually runs pretty cool with the Silver Mountain 2 cooler. Yeah it performs very well with just about anything I throw at it. I love the performance. I also think it's pretty cool that the graphics card is longer than the motherboard 😆
Reply 6 of 14, by gerwin
Since the motherboard uses a late VIA KT chipset, it should support StpGnt and Hlt CPU-idling instructions quite well. Meaning it won't dissipate 100% power at all time, like when just staring at the Windows desktop. At least, that is my experience with the Asus A7V600 motherboard implementation.
Reply 7 of 14, by boggsman
gerwin wrote on 2023-07-03, 15:37:
Do I have to do anything to enable this in WinXP or does it do it by default? Even under load, the Silver Mountain 2 keeps things very cool. I had a smaller copper skive cooler on it a while back and it would get toasty but not anymore.
Reply 8 of 14, by gerwin
boggsman wrote on 2023-07-03, 20:31:
It has been a while, but this old screenshot of mine shows the relevant bits.
On the Asus there was a BIOS option for this.
When power saving is absent the "Thermal Power" value is closer to the "Thermal Design" value.
This is a download for that program. The program only shows its GUI on AMD Athlon/Sempron systems.
Edit; new link that is not dead: https://www.pcworld.pl/ftp/pc_7677/Central-Br … ld-0729-R1.html
Reply 9 of 14, by zuldan
Turning on StpGnt State and Halt State on my GA-7VT600 works great. The power usage massively reduced and my CPU temperature dropped from 36c to 30c and there was no performance impact. I need to try this on my other late VIA KT motherboards.
Do you know if there is another tool to enable those features when Windows starts? I need to run CBI each time Windows boots.
If anyone else wants to try the tool, here are the latest 7.x and 8.x versions. Not sure what the difference is between them.
https://web.archive.org/web/20061008235051/ht … les/cbid77b.zip
https://web.archive.org/web/20070709133559/ht … les/cbid83b.zip
The attachment DE7B4796-4E24-4B42-8774-81589ED0169D.jpeg is no longer available
Reply 10 of 14, by gerwin
zuldan wrote on 2025-03-09, 03:25:
First thing that comes to mind, is to put a shortcut in the Startup section of the Windows Start menu.
Reply 11 of 14, by zuldan
gerwin wrote on 2025-03-10, 13:19:
I wish it was that easy. The tool itself doesn’t automatically re-enable those settings when it starts. It does have a cfg file but there’s nothing in there to set those options. I’ll have to look for some sort of dos command line tool to set them.
This board used to generate a lot of heat but it’s way less. Wonderful feature!
Reply 12 of 14, by The Serpent Rider
IMO it's more efficient to slightly underclock and heavily undervolt Athlon XP. CPU being cool during idling won't do much on a gaming system.
Reply 13 of 14, by Takedasun
Reply 14 of 14, by gerwin
zuldan wrote on 2025-03-10, 19:10:
Right. Seems I used this tool back in the day:
https://web.archive.org/web/20060622023040/ht … .php?sub=CoolON
