MIDI to VGM translator
First post, by bakemono
edit:
Convert MIDI files to VGM files from the command line! YM2151, YM2612, YM2608, YM2203, OPL2, OPL3, and ESFM are supported. Includes Win32, Linux, and 16-bit DOS builds.
see below for latest release and info, or check the blog: http://www.hyakushiki.net/anachro.htm
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 1 of 17, by bakemono
version alpha4 changelog:
Changed the default pitch mapping to one that should be more technically correct.
fixed a bug in SSG channel allocation
faster conversion (runs in reasonable time on 286)
added SSG attenuation switch
added checks for memory buffer (datablob and reproc) overflow
changed a few instruments
Reply 2 of 17, by SuperDeadite
Nice, I will give this a try later. I have a decent setup for all of these chips including 2xOPM. 😀
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 3 of 17, by bakemono
Release alpha5 adds support for OPL3 and dual OPL3... though I don't know if there is any software yet which can play dual OPL3 VGM on real hardware. SBVGM struggles to play single OPL3 on my 286, so I might have to add OPL support to my own VGM player (which has been only for my custom OPN card so far).
Reply 4 of 17, by SuperDeadite
bakemono wrote on 2023-08-01, 18:32:
edit: fixed a minor bug that was causing 'pops' in the audio, and re-uploaded the program
Excellent. MSX VGMPlay does support 2xOPL3/4. Will try this out in a few weeks (I'm on vacation and out of my country right now.) Thanks for the update.
Reply 5 of 17, by bakemono
YM2612 with -s1 switch can now play a MIDI channel(s) on the SN76489 if the notes are all within its frequency range.
OPL3 can now play 9 channels. This is with 2x 2-op channels being paired together to create a 4-op channel. Added OPL2 (4 channels) and dual OPL2 (8 channels). Added preliminary ESFM support which can play 18 channels, though on my 286 there are still a lot pops and crackles, YMMV.
Also including a quick and dirty DOS VGM (and VGZ) player "OPNZ." It can play OPL2/OPL3 stuff at 0x388, and ESFM if you have ESFM. It can play other source material if you happen to have YM2203s at 0x310 and 0x312...
edit: updated archive
Reply 6 of 17, by Scali
My VGM player is prepared for dual OPL3. Never tested it because I don't know of any VGM that has dual OPL3, and no emulator that would give me such a configuration.
But with your tool I can at least create dual OPL3 VGMs.
Modifying DOSBox to have a second OPL3 may not be that difficult.
Reply 7 of 17, by bakemono
Scali wrote on 2023-08-15, 12:17:
Since you mentioned DOSBox, that gave me the idea of testing OPNZ in there. Which promptly failed. Some old redundant code was polling the busy bit on YM2203 and getting stuck in an infinite loop. These lines should have been commented/removed:
;        x=$30
; whileless x,$B3
; callex ,opn1set,opnbase1,x,0
; callex ,opn1set,opnbase2,x,0
; x=_+1
; wend
I'll have to re-upload later.
Reply 8 of 17, by OPLx
Do you mind pointing me to an OPL3 VGM that the slowdown happens on? Back when SBVGM added OPL3 VGM support I didn’t have access to a slower PC. When I have a chance I can try to figure out why it’s slower.
It’s great to see other VGM players; more love for the PC! 😃
Reply 9 of 17, by bakemono
OPLx wrote on 2023-08-21, 11:33:
Sure, no problem.
original MIDI file can be found here (chargeman2): https://www.midishrine.com/index.php?id=53
As a point of reference, SBVGM 1.42 achieves around 50%~80% playback speed on my 8MHz 286.
Reply 11 of 17, by bakemono
Tested a couple of Sound Blaster 16 cards and found that one of them would only play OPL2 stuff, seemingly because of register initialization when switching to OPL3 mode. OPL3 tracks now clear register 8 and don't try to clear register 0xBD in part 2. (It's not clear from OPL3 Programmer's Guide whether that register exists or not.)
-fixed register initialization problem on real OPL3
-added ISC2DMP to convert ISC instruments to DMP for Deflemask/Furnace
-OPNZ now disables interrupts while accessing timer to prevent glitches
-made it a ZIP archive which can be extracted on 16-bit DOS while also preserving file case for Linux
-included a file (opmfreq2.bin) needed to build OPNZ source
Reply 12 of 17, by OPLx
bakemono wrote on 2023-09-16, 16:08:
Register 0xBD doesn't exist in part 2. I found out recently that if there are OPL3 specific settings still set even with NEW bit in register 0x105 set to off, those settings can still affect the OPL3's output. What I ended up doing is:
  • Set the NEW bit on register 0x105
  • Clear all the relevant OPL2 and OPL3 settings
  • Clear the new bit on register 0x105
I'm not sure if the Sound Blaster 16 cards that use a non-Yamaha chip behave when the NEW bit is set or not.
Reply 13 of 17, by bakemono
Updated.
Now includes an XM-to-MIDI conversion tool (win32) where you choose a GM instrument number, volume level, and octave for each of up to 16 XM instruments. Supports volume and panning effects.
Because some MIDIs hit a drum for a very short duration, eg. 8 milliseconds, a minimum key-on time for percussion sounds is now enforced.
OPL and ESFM tracks now leave the sustain bit off.
Fixed a weird bug pertaining to SSG sound, and another one pertaining to notes getting stuck on.
ESFM still behaves strangely sometimes, but in a different way than before 😀
Reply 14 of 17, by TheMechanist
Interesting project ... since Midi files don't contain instrument information at all, playing - and converting - midi files requires a synthesizer / soundfonts .. when I convert some midis to VGM with your tool (Linux) it seems that there is no real soundfont behind the conversion, the result doesn't sound like the Midi played for example with Audacious and Fluidsynth, sounds very flat, more like just playing the notes without instrument pattern ...
Nec Powermate 80286, 12 Mhz, 1 MB RAM, onboard Paradise VGA, 130 MB ST3144AT, ES1868 ISA soundcard, MS Dos 3.31
Unchained demo group
swap42
Reply 15 of 17, by bakemono
Haha, yeah it's FM not a soundfont. It should sound like PC-98, X68000, or Megadrive.
Reply 16 of 17, by bakemono
Updated.
output file ends with a 0x66 code (fixes VGM ROM CREATOR)
new X68000 build, and X68000 player for YM2151 VGMs
supports vibrato using controller #1 (modulation wheel) and XM2MID can convert 4xx vibrato effects
SN76 drums are less buggy and terrible
non-DOS builds allocate more memory to avoid "reproc overflow"
some other tweaks, new options, and a README file
Reply 17 of 17, by bakemono
Updated.
added -r switch for reserved channels
can specify output filename
fixed SN76 drums using chan 3 freq (which was never set to anything in particular)
fixed header endianness on X68
looks for ISC subdirectory in the directory where executable exists (except in Linux)
songs are now allowed to key-on a note when volume is zero (apparently this is a thing)
XM2MID crash fix, support for EEx effect, and 'songloops' option
OPNZ fixes
added OPLL2MID to the archive (converts YM2413 .VGM to MIDI)
