First post, by squelch41
Hi,
I'm running HL2 under windows 98 (obvs without steam)
I know that the engine was updated and so the version of HL2 that is on steam now is the newer engine.
Are there any performance benefits to the newer engine - I could dig out a spare hard drive and install XP but wasnt sure if it was worth it.
Running a P3 1.2GHz so am on the lower limit of HL2 hardware specs (but I found it perfectly playable back in the day and still do!)
thanks
V4P895P3 VLB Motherboard AMD 486 133MHz.64mb RAM, CF 4Gb HDD,
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
386sx 20MHz ICL NB386s laptop, 4mb RAM, modified bios with XT-IDE, CF 512mb, 387 FPU
